Remove Concrete Subfloor In Bathroom? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-30-2006, 02:52 PM   #1
Remove concrete subfloor in bathroom?
I've just moved into a 1929 home that has a concrete subfloor in the 2nd floor bathroom. There is a leak somewhere from the supply or drain piping in that bathroom, leaking onto the dining room ceiling below. In addition, I want to reroute some plumbing, as I'm putting in a clawfoot tub. Access to the pipes from the dining room ceiling is not feasible, since it's an artistic sculptured ceiling. I've started tearing up a portion of the concrete subfloor to get to the pipes, and am contemplating removing all of the concrete subfloor. In that case, I would rebuild a standard subfloor for ceramic tile (plywood subfloor, backer board, etc.). I know it's a huge job, but has anybody done this? Any recommendations or major concerns?
dascreek is offline   Reply With Quote
Old 02-21-2007, 01:17 AM   #2
daman3178's Avatar
I haven't ever done this project but I think it seems pretty much like any other remodeling job. I would suggest taking your time tearing up the floor so you don't damage anything else along the way. It sounds like you know what you are doing so I say just take it slow. I also know you posted this some time ago so if you finished the project let us know how it went and how it turned out for you. Thanks
Damon
daman3178 is offline   Reply With Quote
