Removal Of Wet Bar - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-30-2008, 11:20 AM   #1
Removal of Wet Bar
We removed the wet bar in our living Room and found that we have a 3" schedule 40 drain pvc pipe from upstairs down into the foundation. About 4 inches from that pipe is 1 1/2 inch pipe that is connected to the 3" pipe about 5 inches from the floor.
I want to connect the 1 1/2" pipe to the 3" in the ceiling so I only have one pipe to build a fluted column around.
Will this present any problems in the future.
Thank you
rvourganas is offline   Reply With Quote
Old 11-30-2008, 08:28 PM   #2
Registered User
Termite's Avatar
It might not be that easy. The pipe may be a vent. Can you take a picture or post an illustration of what you're dealing with?
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Lead paint removal Luken8r Painting 3 05-15-2008 08:05 PM
Sheet Vinyl Flooring Removal yoods Flooring 2 11-22-2007 01:04 PM
