Removal Of Uncured (still Soft) Silicone Sealant - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-22-2010, 07:25 PM   #1
Removal of Uncured (still soft) silicone sealant
While trying to seal the bottom corner of my concrete basement for a
seeping leak, I unknowingly used an Old Tube of DAP Silicone Clear Sealant.
It will not harden or cure, but remains soft and sticky to the touch. I am prepared to scrape it out, as best as I can, but need to know what will dissolve and remove the rest that will still be sticking to the concrete wall.
What is a good solvent to use? Thanks.
Hardy is offline   Reply With Quote
Old 01-22-2010, 10:39 PM   #2
Rewards Points: 1,088
Scrape as much off as possible, and then try Goof Off.
handy man88 is offline   Reply With Quote
Old 01-23-2010, 07:54 AM   #3
Use this product it's called McKanica Silicone Caulk Removal it comes in a tube about Oz. the tube is a purple color ACE Hardware store has it or you can check on line. 8.99 for a tube.
I used it to remove an old sink from a counter top it worked of course you have to play with it.
SULTINI is offline   Reply With Quote
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 36 02-24-2016 03:01 PM
How to seal my attic access - airtight? akoch General DIY Discussions 4 09-08-2008 09:03 PM
Recaulking Bathroom Help RaeEllen Remodeling 9 07-25-2008 11:23 PM
....silicone still uncured days later!?! joeyboy General DIY Discussions 12 05-09-2008 08:10 PM
