Removal Of Support In Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-20-2008, 07:29 AM   #1
Removal of support in basement
Hi. I'd like to remove a support in my basement that is in the worse possible spot in my woodworking shop. It's driven me nuts and it's simply gotta go one way or another.
You can see from the photos that the post is constructed of four 2X4s. The column supports three 2X10 joists across a 14 foot span. Directly above the joists is the wall between our kitchen and dining room and above that is a bedroom. The 2-story wood frame (colonial style) house was built in 1992.
What I'd like to do is place a temporary (18 inch long) 4X4 perpendicular to and underneath the 3 sandwiched joists. The 4X4 would be supported by 2 temporary jacks at each end of the 4X4. This temporary support would allow me to remove the 2X4 column and allow room to run a engineered I-beam or LDL parallel and below the 3 joists. The new beam would be supported on each end by vertical 4X4's attached to each wall.
Because there's ductwork below the 3 joists, there woudl be a 14-inch space between the 3 joists and the new support. I'd add a few short vertical 2X4's between them to support the joists.
Question - does this sound like the way to remove the column? Is there a better way?
Removal of support in basement-127_2712.jpg   Removal of support in basement-127_2716.jpg
juno96blue is offline   Reply With Quote
Old 01-20-2008, 10:45 AM   #2
ICF Construction
You really need someone to come and look at that for you, removing a post without ALL the details is dangerous, things to be considered are span of floor joists, span of beam, whats on top, single, two or three story? you may need to add new posts which require a footing
Hire a local engineer to review.
Nice workshop, but structural work is not a hobby
Chris
Chris Johnson is offline   Reply With Quote
Old 01-20-2008, 11:04 AM   #3
I guess I agree. I called a structural engineer awhile back and he charges $145/hour - including travel time. Obviously, that's nothing in comparison to the value of the home and peace of mind but I'd rather not spend $450 for the answer.
If anyone can recommend a reasonably priced structural engineer or experienced carpenter in the Zionsville (Indianapolis, Indiana) area, please let me know.
Old 01-20-2008, 04:25 PM   #4
Rewards Points: 6,652
It was probably done that way, so that a wall could be put in later to divide the Utility space from the downstairs living area. Is there any way that you could post 3 other shots (Left, Right, and Other Direction) from the Table saw to show space on those sides?
Old 01-20-2008, 05:05 PM   #5
What is the total span of that beam?
jerryh3 is offline   Reply With Quote
Old 01-20-2008, 11:04 PM   #6
Total span
The total span (from wall to wall) is 14 feet.
Basement - Removing or moving support post jfgagnon Remodeling 12 08-08-2011 07:11 AM
IRC 404 Basement walls lateral support? bjr23 Building & Construction 2 07-26-2007 09:07 AM
Need help with basement support jaw522 Building & Construction 3 10-25-2006 08:55 AM
Temporary support for replacement of basement beam Mikedks Remodeling 8 09-14-2006 06:36 PM
