Removal Of Old Concrete Attached To Good Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-03-2014, 03:32 PM   #1
Removal of old concrete attached to good slab
I'm planning to pour a new slab next to the exisiting slab in my backyard. The previous homeowner built a low deck adjacent to the slab, which I've removed. He anchored the deck with a few concrete pours, 3 of which we poured right up against the good slab that I would like to keep. So how do I remove these without harming the slab that I want to keep or could I just remove enough of these so that I could pour the new slab on top, since one of them, pictured below, is holding up my awning.
Removal of old concrete attached to good slab-camerazoom-20140401073031540.jpg   Removal of old concrete attached to good slab-camerazoom-20140401073022828.jpg
chuckd98036 is offline   Reply With Quote
Old 04-03-2014, 05:43 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Ayuh,.... Once ya got the grade dug out, 'n ready to form the hole,....
I'd just knock the tops off of 'em, 'n pour over 'em,...
Concrete over brick over post tension slab M3 Pete Concrete, Stone & Masonry 6 01-21-2013 05:37 PM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 11:19 AM
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 02:45 PM
Cork or engineered wood over concrete slab w/ Radiant heat, HELP! newdyier Flooring 9 11-04-2008 04:11 PM
