Old 01-31-2012, 04:48 PM   #1
removal of load bearing wall
is it possible to remove a small 8 ft load bearing wall and keeping the ceiling flush .without seeing the rsj protruding
Carlos 45 is offline   Reply With Quote
Old 01-31-2012, 05:10 PM   #2
"rsj"..."rsj"...? Real smelly junk? Red sock jump?
FYI, the more detailed your question is, the more detailed your answer will be.
B
Beepster is offline   Reply With Quote
Old 01-31-2012, 05:10 PM   #3
MarginallyQualified
If you're willing to completely re-frame the floor joists above... maybe to probably.
It's a seriously big and expensive and absolutely PRO job...
starting with the engineering.
Old 01-31-2012, 05:12 PM   #4
Beanfacekilla's Avatar
I really think more information is necessary to answer this question. A picture is worth 1,000 words.
I think if you chose to come here and ask, you are probably not ready to tackle this project.
If you are determined, I would seek the advice of an archy or engineer. Moving a load bearing wall is a serious project, and needs to be planned and built correctly.
There is alot more to it than what they show on the DIY channel. I am not trying to sound smug or rude. This topic frequently comes up on this forum (and I haven't even been here long).
This is all my opinion. Take it or leave it.
Peace.
Beanfacekilla is offline   Reply With Quote
Old 01-31-2012, 07:25 PM   #5
Disabled wood vet
titanoman's Avatar
If it's a bearing wall, it can be replaced with a beam, put in the attic and the ceiling joists hung from it, but a lot of factors go into determining what size beam you would need. Either interpret the UBC, or talk to the good people at your local friendly building department.
titanoman is offline   Reply With Quote
load bearing wall question mudpaws Carpentry 3 06-24-2011 10:39 PM
Is this wall load bearing - pictures attached jen5219 Building & Construction 16 08-01-2010 01:17 PM
Load Bearing Wall Issue? iggy913 Building & Construction 1 07-28-2010 07:45 PM
Is this Load Bearing Wall remodel-virgin Building & Construction 16 05-11-2009 05:25 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 08:37 AM
