-   -   removal of load bearing wall (http://www.diychatroom.com/f19/removal-load-bearing-wall-132126/)
Carlos 45 01-31-2012 03:48 PM
is it possible to remove a small 8 ft load bearing wall and keeping the ceiling flush .without seeing the rsj protruding
Beepster 01-31-2012 04:10 PM
"rsj"..."rsj"...? Real smelly junk? Red sock jump?
FYI, the more detailed your question is, the more detailed your answer will be.
B
TarheelTerp 01-31-2012 04:10 PM
If you're willing to completely re-frame the floor joists above... maybe to probably.
It's a seriously big and expensive and absolutely PRO job...
starting with the engineering.
Beanfacekilla 01-31-2012 04:12 PM
I really think more information is necessary to answer this question. A picture is worth 1,000 words.
I think if you chose to come here and ask, you are probably not ready to tackle this project.
If you are determined, I would seek the advice of an archy or engineer. Moving a load bearing wall is a serious project, and needs to be planned and built correctly.
There is alot more to it than what they show on the DIY channel. I am not trying to sound smug or rude. This topic frequently comes up on this forum (and I haven't even been here long).
This is all my opinion. Take it or leave it.
Peace.
titanoman 01-31-2012 06:25 PM
If it's a bearing wall, it can be replaced with a beam, put in the attic and the ceiling joists hung from it, but a lot of factors go into determining what size beam you would need. Either interpret the UBC, or talk to the good people at your local friendly building department.
