Old 10-30-2012, 12:08 AM   #1
Removal of load bearing brick wall
I have a load bearing brick wall (3.5 ft wide by 8 ft high), its was left un touch from our addition left from our previous owner. We would like to remove this brick wall to complete our kitchen renovations.
Does anyone have a good engineer and or contractor that you can recommend to get this job done?
see attached pic.
Thanks,
Mojoaalis is offline   Reply With Quote
Old 10-30-2012, 12:13 AM   #2
Need to be getting some local referances and make some calls in your area.
Not sure how anyone here could suggest anybody anyway since you did not add your location when you filled in your profile.
Old 10-30-2012, 12:17 AM   #3
That's a really good point! I am in the Toronto Canada area.
Old 10-30-2012, 12:33 AM   #4
Give this guy a call:
Picco Engineering
info@picco-engineering.com
he is in the Concord area
I have used him a couple of times...
epson is offline   Reply With Quote
Post replaced by load bearing wall cgio Building & Construction 3 02-11-2012 03:18 PM
Finding Load Bearing Walls Dane Hitchins Building & Construction 15 05-14-2011 11:09 AM
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 05:33 PM
Is this Load Bearing Wall remodel-virgin Building & Construction 16 05-11-2009 05:25 PM
Load bearing wall removal marquez29 Carpentry 16 03-30-2009 01:34 PM
