-   -   Removable Well house construction. (http://www.diychatroom.com/f19/removable-well-house-construction-153078/)
Randell Tarin 08-08-2012 03:49 PM
We have just had a new water well drilled. The tank and pump's electrical workings set on a 45" square concrete slab. The tank is approximately 6 feet tall.
I would like to construct a well house that will match the cedar siding of my house, but at the same time, be rigid enough to be lifted by a crane from it's base should the well pump need to be replaced. I'm thinking an eye-bolt attached to the roof beam would provide something for the crane to have something to hold on to.
Basically, it will be a three-sided building, the fourth side being mostly the door into the enclosure. The sides would be secured to the sill plate attached to the concrete base by easily removable screws. The roof and walls would need to be integrated to keep them together. Weight is not a huge issue, but I guess lighter is better.
It seems like conventional stud and siding construction would buckle if lifted without some sort of diagonal bracing at the bottom. Suggestions?
Has anyone ever built anything like this?
Blondesense 08-08-2012 04:23 PM
We had a well house back when we lived in Texas. As I remember the roof was removable versus lifting the entire thing. Other than that I don't recall how it was built.
Have you talked to the well company about what they would recommend?
I suspect they have been down this road before and may even have plans available.
Randell Tarin 08-08-2012 05:25 PM
Their "idea" was not aesthetically pleasing. We run a B&B, so it needs to look good to blend with the surroundings.
gregzoll 08-08-2012 06:18 PM
Just make it, so that the walls and roof are bolted together. I doubt that you would have to move the structure for at least 20 years or so.
joecaption 08-08-2012 07:31 PM
Post a picture of what you have now.
What type well is it?
Evstarr 08-08-2012 08:15 PM
I would go with something utilitarian and acceptable to the well people and put a fence around it to suit your aesthetics.
