Remortaring Inside Of Foundation Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-18-2011, 02:37 AM   #1
Rewards Points: 156
Remortaring inside of foundation wall
I've got an old clay block foundation and the mortar is crumbling badly. It's really old. Would it be a good idea to remortar this wall from the inside? Also, I should mention that there's a thick coating of paint on the foundation wall and it looks to be thoroseal. It's chipping off in many areas but some of it is still bonded to the wall pretty good after many many years.
Any suggestions on how to fix the walls up? Is it even necessary? Does remortaring strengthen the wall at all? There's some holes in it scattered about which I have filled with big gap spray foam.
strategery is offline   Reply With Quote
Old 10-18-2011, 04:31 AM   #2
Rewards Points: 4,796
some pics would help but, in the meantime, spray foam is NOT structural material -works fine for keeping out critters
thoroseal is a coating, not paint,,, i'd guess ( in residential use ) diy'ers would've used drylock-type product
Old 10-19-2011, 03:11 AM   #3
Rewards Points: 156
thoroseal is not a coating but paint
I know that spray foam has no structural value. I simply needed something to fill in the voids to keep pests and rodents out of my house.
I don't know much about thoroseal but I was told that it's probably what it is.
Old 10-20-2011, 12:25 AM   #4
Rewards Points: 156
Does anyone know if a pressure washer will help me clean up the walls? Would it be a good idea to rent one to clean up the walls so I can look at remortaring the bricks?
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Cutting into foundation wall to install entry door. notenoughtime Building & Construction 7 08-19-2009 02:13 PM
subpanel mounting on concrete basement foundation wall bulk88 Electrical 12 03-10-2009 01:38 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
