Remodeling Deck Surface- How? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-23-2013, 12:54 PM   #16
You didnt mention where this house is loacted. Is the sun Bad? Hummidity? Near water? Freeze/thaw? It doesnt look like it's easy framing to get to, so I would do it in steel. For the decking, it matters about sun and the other things I listed. I live in Colorado, and nothing stands up to the sun except real stone; and yes it is possible. I just need more info.
peakcelln is offline   Reply With Quote
Old 01-24-2013, 03:26 PM   #17
Rewards Points: 1,062
Originally Posted by reegsr View Post
I know this may not be what you're looking for, but have you ever seen deck tiles? they are wood but come in pre fab tile portions.
kinda want to stay away from wood.....
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 01-24-2013, 03:30 PM   #18
sunny dry area. gets 32 deg F to 100F. yes, i like rock.
Old 01-29-2013, 04:30 PM   #19
Roofmaster
Rewards Points: 2,172
You are dealing with what is considered a low slope plaza deck installation. You have still not told us what type of roofing you have in place, but I suspect it is because you do not know. This is going to be like pulling teeth, judjing by the fact that you gave me one wide view of your deck and thats it. Based on your location, I suspect you have one or two plies of D-226 felt mopped in ASTM D-312 type III asphalt and a mopped 90 lb. Granular Surfaced cap sheet. This is pretty standard in So. California.
Some questions:
1. How does you roof drain? I know you said it has slope. Which way?
2. How are you current posts attached?
3. Remove those few short boards where your deck abuts the slab and take a couple of pictures. Remove a couple of deck planks and lets see a post base.
4. What does your current structure consist of? I need to determine allowable loads.
5. Does your current roof leaking into the garage or under the slab? Tell the truth now............
I will tell you how to do this project, but need info. Take a look at Hanover Prest Pavers. They are the only thing that lasts on a roof due to their 8700 PSI Density.
Forget tile.
22x14 DECK W/ROOF SLIGHT SWAY NEED HELP FROM EXPERTS clfdpops1 Building & Construction 38 06-09-2012 07:21 PM
Building Floating Deck over ground and Concrete slab jagnew Building & Construction 2 05-27-2012 01:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Deck at seasonal camp site... Spike99 Project Showcase 0 12-24-2007 04:09 PM
