Remodeling Bathroom - Question Regarding Cement Board - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-27-2011, 05:38 PM   #1
Remodeling bathroom - question regarding cement board
I am remodeling my bathroom and installing a new tub. The tub is not equal on both ends next to the walls. I am installing the cement board to install the tile on, however, when I measure the cement board on either side of the tub, it is not equal on both sides next to the wall surface. What can I do to install the cement board to make the width of the board with the tile equal on either side?m The back and one side are up against the 2 x 4's - the other side is 1/2" to 3/4" away from the 2 x 4's. How do I make it even?
prontocruz is offline   Reply With Quote
Old 06-27-2011, 05:43 PM   #2
DIY staff
Rewards Points: 7,174
A picture will help---a lot-----
The tile is frequently wider at one end-of a tub surround---I've never seen that as a problem--
You have to work with what was built.---Mike---
Old 06-27-2011, 06:11 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If we knew how much "not equal" it was, that would be helpful.
XXX
Cement Board Questions trophywalleye Drywall & Plaster 17 06-29-2011 10:56 PM
Correct use of moisture resistant Purple board in Bathroom? fromscratch Drywall & Plaster 19 06-19-2011 11:18 PM
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 06:29 PM
Basement Bathroom Tiling Question KUIPORNG Flooring 1 07-22-2006 11:03 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
