Remodeling Attic Space
Yes, 2x8's would be enough nailed to the 2x6's, if your knee walls do not carry much of the roof load. If they did, you would consult a Structural Engineer in your local area, as he would know your wind and snow loads on the roof structure. As stated using listed materials, you could safely carry 66# load, instead of code minimum 40#. Be sure to furr down the room rafters for required insulation for your location, leaving 1" next to the roof sheathing/insulation for ventilation air flow. Or use extruded foam board to add minimal furring and meet your energy code. Ridge vents (continuous) with baffles, balanced soffit venting sized for your roof (25 x 30= 750 / 150= 5sq.ft.= 1/2 ridge, 1/2 soffit) sealing all ceiling penetrations, etc. Any other questions? Or just click on my name in blue, as I have answered this many times before. Be safe, Gary
