-   -   remodeling (http://www.diychatroom.com/f19/remodeling-99862/)
dakotaxyz 03-28-2011 03:41 PM
remodeling
the project we want to do now involves one of our bathrooms. after removing the carpet/padding/tack strip we discovered the concrete floor has a fine crack approx five inches in size. it is a fine crack with one side just a touch higher than the other side. my question is what steps should we take to fix this problem.
dakota
Gary in WA 03-28-2011 09:31 PM
I'll move you to B&C where you will get faster answers....
Gary
rossfingal 03-28-2011 09:35 PM
Hi! Dakotaxyz
A picture(s) would help!
What are you going to put on the floor?
Regards! :)
rossfingal
Bud Cline 03-28-2011 09:42 PM
There's the first question.:)
dakotaxyz 03-29-2011 01:40 PM
remodeling renamed bathroom
we will be putting tavertine tile on the bathroom floor. and after checking again the crack is even and not one side higher than the other as i was told.
Bud Cline 03-29-2011 06:06 PM
My question is what steps should we take to fix this problem.
If you are sure the crack doesn't have a heaving side to it there is no fix required. At the very least however I would suggest you use an isolation product of some kind. Something like Schluter DITRA will work but if the floor heaves slightly all bets are off.:) Travertine wouldn't be the best product to use under the circumstances.:) It is very vulnerable to movement. I think I would use DITRA and install the tile with Custom's Megaflex thinset for an extra measure of safety.:)
dakotaxyz 03-30-2011 12:22 AM
since u don't think travertine is a good choice for this room now. what do you recommend? the store where i took a tile class recommended that i use fiberglass and hydroflex to fix the problem. what is your opinion about this fix? also is using a floor leveling substance a good or bad idea as the floor is a little slanted, just a little.
Bud Cline 03-30-2011 06:14 PM
Travertine in its natural form comes with imperfections that are mostly hidden. Travertine is also a soft stone as rocks go. It is a beautiful product and of course very popular right now but considerations are in order when deciding whether or not to use it.
Since you already have a crack and you probably don't know if this crack moves a little it is conceivable that travertine may not be the better choice. There are a lot of porcelain tiles available that mimic travertine beautifully and that may be the better choice in your case. Check out the porcelain and see what you think.
The store where i took a tile class recommended that i use fiberglass and hydroflex to fix the problem.
Fiberglass? Fiberglass what?
What is "Hydroflex"? Is that the name of the manufacturer? Is it a thinset mortar? I know of Hydroment. But according to Google Hydroflex makes cameras and surf boards and automotive hoses and there is a Hydroflex Hydraulic system but I didn't turn up any tile related Hydroflex anything.:).
What is your opinion about this fix?
I already suggested the use of DITRA.
Also is using a floor leveling substance a good or bad idea as the floor is a little slanted, just a little.
A lot of patching products sport the name "floor levelling compound"...
I'm not much help if I don't have some brand names to go by.:)
