Remington Heater Problem - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-29-2010, 12:09 PM   #1
remington heater problem
Have a remington multifuel torpedo heater that runs for about 10 mins then there is smoke. i can unplug and plug in and it does the same thing. What part should I replace?
allcircuit is offline   Reply With Quote
Old 12-29-2010, 01:13 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 360
Ayuh,... I donno, but I wanta say,...
My Dad gave me 1 of those years ago,...
I've tried to use it several times, it Never works right, unless it's about 70 out...
Of course, at 70 I don't need it to work...
At any tempertures below that,...
It fires, 'n runs for maybe a minute, then quits, 'n smokes..
I'm pretty Handy, but sent it out for repairs anyway,...
After $50. in repairs,...
It still does the same thing...
Talkin' to my Bil some years ago,...
He told me that's Why Dad gave it to me,...
He couldn't get the dam thing to work Right either....
Bondo is online now   Reply With Quote
Old 12-30-2010, 01:39 PM   #3
Drywall contractor
Rewards Points: 1,070
Rather than just "throw some parts" at it until you figure out the cause, I'd try an internet search OR have someone fix it for you. I've got a heater (different brand) I've had for at least 15 years and have never even replaced the plug in it. I DO take it apart and blow all of the dirt/drywall dust out of it annually and replace the filter. Talk to someone at your local tool rental store. They can probably give you advice as to what MIGHT be the cause or do the repairs for you....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 01-24-2011, 02:02 PM   #4
Fuel filter!
I would bet it is the fuel filter--I had the same problem. I found the user manual for my heater, complete with a troubleshooting guide. When I pulled the fuel filter, it was almost completely clogged. After cleaning it my heater runs like a jet. I also cranked the pressure to high, which helped to bring hotter, cleaner air.
Here is the manual for my heater:
http://www.managemylife.com/mmh/owne...ctric-L0407378
Note, do not move the heater while it is working! You will stir up the crud in the fuel tank and suck it into the filter and create a clog.
Good luck
kmenzel is offline   Reply With Quote
Old 01-24-2011, 03:07 PM   #5
Rewards Points: 1,532
Bondo,
Good one!
bob22 is offline   Reply With Quote
???A.O.Smith Water heater problem??? wrennels Plumbing 1 10-19-2009 08:57 PM
Baseboard Heater / Power Cord Problem channingg General DIY Discussions 8 10-02-2009 12:35 AM
Heater starts...then stops. Help! beagan HVAC 3 12-04-2008 03:40 AM
problem with water heater Charles Sexton Plumbing 2 10-12-2008 09:55 AM
help to diagnose pilotless heater problem jpplumber HVAC 30 01-02-2007 09:11 AM
