Relocating Plumbing - Concrete Slab Foundation - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-23-2011, 12:30 AM   #16
Rewards Points: 1,016
Originally Posted by rossfingal View Post
Just trying to help, if possible!
Regards!
rossfingal
Yes, and the help is appreciated!
Did not mean to convey otherwise if I did.
The Following User Says Thank You to vsheetz For This Useful Post:
rossfingal (04-23-2011)
Old 04-23-2011, 12:31 AM   #17
Originally Posted by AndyGump View Post
Most post-tensioned slabs will have an embossing in the slab in one or two places, usually by the garage door saying something to the effect that this is a post tensioned slab.
You really couldn't miss them if they were there.
You will also have to prepare the cut concrete section like it was a new slab when you pour the patch for it. Drill and epoxy holes for rebar to connect old to new, compacted gravel and/or sand, 6 mil. vapor barrier, etc.
Andy.
Thanks - I had not given much thought to closing up the holes, just making them.
Old 04-23-2011, 05:22 AM   #18
Rewards Points: 2,240
@AndyGump
Thanks!
@vsheetz
Yeah, closing up the holes is a lot more "fun"(??) - than making them!
rossfingal
rossfingal is offline   Reply With Quote
affixing PT 2x4 sole plates to concrete foundation amakarevic Building & Construction 6 12-21-2010 08:28 PM
Replacement concrete garage floor, dowelled into foundation? Niffumdutz Building & Construction 5 02-19-2010 08:31 PM
PVC underneath the floor (concrete slab) massimo Building & Construction 6 11-19-2008 10:37 AM
pouring a level concrete slab over sloped concrete Jayne Building & Construction 4 05-11-2008 08:55 AM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
