Forums | Home Repair | Home Improvement | Painting | Interior Decorating | Remodeling | Landscaping
Old 12-22-2010, 04:04 PM   #1
Share |
relevel a foundation on outside from underneath
our house is 35yrs old & is starting to settle in the kitchen area.it is noticeable from outside by looking at the brick.the tiles in the floor are also separating;i want to add another room from here but want to level the foundation first.i have heard to dig under where the corner is and use jacks underneath til it looks good & then fill it with concrete.does this sound right?
snookie8791 is offline   Reply With Quote
Old 12-22-2010, 04:15 PM   #2
Civil Engineer
You need to supply a lot more information before asking such a broad question. Specifically, exactly what type of foundation do you have? How much settlement has occurred, and how accurately did you measure? What type of framing do you have in the house? What type of soil is the house on? How is the interior of the house constructed? You get the idea. Else the question is impossible to discuss.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
snookie8791 (12-22-2010)
Old 12-22-2010, 04:21 PM   #3
4inch concrete foundation .the wood frame is on 19 inch centers
Old 12-22-2010, 05:01 PM   #4
Stay-at-home GC
Is it bigger than a breadbox?
Seriously, this is a huge project and discussing it one word at a time is going to take a LONG time.
Yes, in theory you are correct. "All you have to do" is excavate under the foundation or footer. Raise it to the correct height and underpin it with a new footer.
But that is equivalent to saying all you need to do to get to the moon is "go that way really fast. If something gets in your way, turn" (Thumbs up for the obscure 80's movie ref).
4" of concrete is likely your slab. Your best bet is to start with a couple of books on foundations. At the MINIMUM for starters, you'll need,
1. How deep has it settled? Is it still settling? How do you know? Is it worth x thousands of dollars in rehab to pick up 3/4" level.
2. Your type of footing and its depth
CplDevilDog is offline   Reply With Quote
Old 12-22-2010, 05:05 PM   #5
joed's Avatar
If it is a slab then pump jacking could be an option. They drill holes and pump concrete under the slab to raise it back up to level.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 12-22-2010, 06:12 PM   #6
no bsmt mentioned - you MIGHT have a 4" slab but its also likely its a monopour/unipour/thickened edge footer ( foundation ),,, just my suggestion you call in a pro engineer - you'll need accurate measurements, cores of the floor to ck thickness, determine if its a post-tensioned slab, mono/uni/te, excavation, etc,,, what you mentioned is an underpinning which may OR may not be the right choice/method
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Stone Foundation 'Temporary' Repair... Peter B. Building & Construction 17 12-16-2010 12:27 PM
Round House Foundation Feasibility Mswick Building & Construction 23 02-27-2010 08:34 AM
Foundation Has Settled 1/4 inch Need to Relevel Noticed Something Odd cloves Flooring 8 11-04-2009 05:20 AM
Foundation Repair Help rasilun Remodeling 1 10-15-2009 10:26 PM
How to add footing and foundation to existing foundation? ptcamaro Building & Construction 6 06-22-2009 10:22 AM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
