Rejuvinating A Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-20-2012, 05:38 PM   #1
Rejuvinating a deck
I have a weathered deck, 2X6 pressure treated pine installed with spiral shank galvanized nails. I am thinking about setting the nails about 1/4 inch and then sanding or planing the surface of the boards. What do you think? What is the best tool to set the nails? The trim carpentry nail sets seem too small for this.
diyerinatl is offline   Reply With Quote
Old 05-20-2012, 06:31 PM   #2
Too Short? Cut it Again!
You can find a larger diameter nail set but those type nails may fight being set down under the surface.
Also, you sure you don't want to see what the boards look like on the other side before committing to resurfacing the exposed side? You might be better off flipping them over.
Old 05-20-2012, 07:10 PM   #3
firehawkmph's Avatar
Rewards Points: 1,822
Diyer,
if you decide to set the nails, get a drift punch made for automotive use. They have different diameter ends and are larger than a nail set. As far as flipping the boards, I've never seen that done with any success. If the deck was nailed with spiral shanked hot dipped galvanized nails, they usually break before they pull out. Set your nails and get a large belt sander (4") and a handful of rough grit belts. You can clean things up pretty well with that, depending on how big your deck is.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 05-20-2012, 07:41 PM   #4
Mike, agree with you except that sometimes flipping the boards works out. Given the spiral nails it would be a chore and they would probably have to be cut off with a saws all or something.
What worries me is that the OP is starting with treated pine which is pretty soft to start. I guess success depends on how bad the surface is. Since the OP is suggesting sinking the nail heads 1/4" I guess I assumed he was thinking of sanding or somehow power planing off a fair amount? The good news if this is the case is that the wood is soft pine and it could go fairly fast.
Old 05-20-2012, 08:35 PM   #5
robertcdf's Avatar
A 40D or 60D nail with the end blunted makes a fairly good nailset for larger nails.
robertcdf is offline   Reply With Quote
Old 05-20-2012, 09:29 PM   #6
Thanks!
Thanks for the replies. Good ideas on the nail set. The deck boards have grooves on the underside that I think are intended to minimize warping. Flipping is not an option.
Thanks!
Old 05-20-2012, 10:23 PM   #7
Rewards Points: 628
most of the time a good pressure washer and the right tip will clean them right up the reseal the deck after a few days of drying. if it is real bad after that you can let dry and use a floor sander "can be rented" to smooth out as needed then seal
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
The Following User Says Thank You to jaydevries For This Useful Post:
Ravenworks (05-21-2012)
Old 05-20-2012, 10:56 PM   #8
Structural Engineer
Good luck on your project! I tried to do the same thing. My decking was too cracked and the sanding was not coming out too well. So I ripped off the decking and installed composite decking with stainless steel screws. I pre-drilled and used a countersink bit for all the screws. It looks awesome and I'm happy I went that route.
House Engineer is offline   Reply With Quote
Old 05-21-2012, 08:47 AM   #9
AHH, SPANS!!!
Rewards Points: 1,166
you might want to do a sanding test run before committing to nail setting all of those. as mentioned above, the idea of using a 20,40,or 60d nail for a punch is great! for my nail punch I start out with a smaller trim type punch and after use it wears down and turns into a regular size punch. a tip for punching nails- at the time the deck was built the nail is not always driven in perfectly vertical when driven so try and determine if the nail head is on an angle and drive the punch in at the angle of the nail head. also, sometimes after the first slam with the punch, the nail head will bend one way and the nail the other. use the punch on an angle and try and straighten the nail back up and then redrive/punch it down directing the point of the punch against the raised side of the bent nail head. hope that made sense.
hand drive is offline   Reply With Quote
Old 05-21-2012, 09:05 AM   #10
Rewards Points: 258
Pressure washer can chew up that soft wood, though there is no other good way to get the mildew off, if that is the problem. Well, sanding I guess.
puttster is offline   Reply With Quote
Old 05-21-2012, 05:09 PM   #11
House engineer, I looked at composite and liked everything about it except the expense. I used a belt sander on about a square foot to see how it would work on a small space. I think it will be fine.
Hand drive, Yes that made sense. There are definatley a number of nails that were not driven straingt. I thinkt I can set them with a large blunted nail. I will just grind the end off.
I already pressure washed. The part that is under cover looks great. I want to remove the shallow grooves that are all over the part exposed to the sun. I think this will work and make it look much like it did when it was new.
Thanks for all the help!
Old 05-21-2012, 05:28 PM   #12
kwikfishron's Avatar
Rewards Points: 172
Rent a belt floor sander.
It will make real quick work of it.
kwikfishron is online now   Reply With Quote
Old 05-21-2012, 05:32 PM   #13
Ravenworks's Avatar
You need to be careful,been doing mine every 3 years for awhile now.
U.S.M.C. "80-84" E.O.D. 1369
Ravenworks is offline   Reply With Quote
Old 05-22-2012, 09:22 AM   #14
AHH, SPANS!!!
It is great you have it figured out! please post before and after pics if you have time to do so
Deck Staining Nightmare steven994 Painting 6 04-06-2014 10:10 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 12:36 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
Rejuvinating an old deck Proulx06 Building & Construction 10 09-12-2008 07:15 PM
