Reinstalling 'new' Window That Had The Nailing Flange Cut Off On Removal? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-05-2011, 11:27 PM   #1
Reinstalling 'new' window that had the nailing flange cut off on removal?
I was recently given a new (3 month old?) vinyl window that was removed as part of a remodel.
Unfortunately, during the removal the contract cut the window out of the opening, removing the entire nailing flange in the process.
What can I do in order to install this window in our house?
Do they sell replacement nailing flanges that glue(?) onto the old window?
cerestes is offline   Reply With Quote
Old 01-05-2011, 11:33 PM   #2
What Mfg window ?
The andersen windows/doors I bought have removable flanges
I bought a new set of flanges ($60) for a new 2x door that I was given
Door was brand new, but flanges were missing
Old 01-06-2011, 12:17 AM   #3
firehawkmph's Avatar
Rewards Points: 1,822
Most of the vinyl windows with built in nailing flanges make the flange as part of the extrusion. Replacement vinyl windows are normally made without the flange. They fasten to the jambs with four screws, one in each corner, on the vertical sections only. If you look at each side where the sashes travel (if this is a double hung) you may see a removable cap top and bottom, about 4" tall and an inch wide. Pop it out and there should be a pre-drilled hole to run the screw through. You may not have the same setup on your window, but you get the idea on how to mount them to the jambs. If you go to your local big box store, take a look at their replacement vinyl window display and you will see what I am talking about. Should be simple to adapt over to your window.
Mike Hawkins
firehawkmph is offline   Reply With Quote
vinyl window without nail flange??? rb69 Remodeling 4 08-25-2010 06:26 AM
Bathtub nailing flange escoleone Kitchen & Bath Remodeling 1 04-25-2010 03:21 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Single Hung Window Removal for Drywall bparise Drywall & Plaster 2 12-12-2009 08:44 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
