Reinforcing Subfloor Around Toilet *PICS - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-15-2012, 08:53 PM   #1
Rewards Points: 115
Reinforcing subfloor around toilet *PICS
Looking for some input as to whether or not this would be a sufficient job. Thanks. Appreciate the help I've received in the past.
Pic 1: 1974 Ranch with Post and beam construction (No joists supporting the toilet and oversized hole currently. Subfloor is T&G dimensional lumber)
Pic 2: Larger square hole cut out, then 2X6 joist installed right up to cut (View from crawl space looking up at bottom of floor)
Pic 3: Sistered joist added to act as nailer for new subfloor
Pic 4: Additional blocking added to act as nailer
Pic 5: New subfloor patch added, T&G remnant from house or layers of plywood to obtain same width of existing subfloor.
Pic 6: Blocking removed to show how pipe sits
Didymus21 is offline   Reply With Quote
Old 10-15-2012, 09:03 PM   #2
Rewards Points: 13,712
No clue why your making a square hole for a round pipe.
Is the subfloor rotted out now and your just trying to patch it together?
If you used 3/4 Advantec subflooring there's really no reinforsement need.
If you feel for some reason you need to add something no big deal just add a couple of single 2 X's one on each side.
Old 10-15-2012, 09:13 PM   #3
Rewards Points: 115
The current hole is oversized for a closet flange. Don't ask me why the previous owner did that. I bought the place without the toilet installed and knew this would be a repair. I suspect it had been rotted out and cut previously.
I'm also reinforcing the floor for tile because it's overspan with the post and beam. That's another reason why I'm adding the joist.
Old 10-15-2012, 09:27 PM   #4
Then why would you not just cut out the subfloor and install a new patch, this time with a nice round correct sized hole?
We have to keep guessing like this when there's no picure of the floor your working on.
Old 10-15-2012, 09:52 PM   #5
Rewards Points: 115
I don't see why posting a pic of the actual floor will make a difference. I drew it in the program fairly accurately with better visuals and angles of the issue than a picture could yield. I added information to the original post for clarity.
Cutting out the subfloor is exactly what I proposed to do. I wanted to know how to properly support the patch that I'd be adding, since it was T&G subfloor over post and beam with a large unsupported span below the toilet.
Here you can see I've already installed the ledger board in anticipation of putting more joists in.
It'd be very much like this video I found (only waste pipe would run up through a round hole.
Old 10-15-2012, 10:19 PM   #6
Rewards Points: 236
i like your idea. so much so, that is how i plan to do mine. toilets take a lot of abuse and weight.
Fix'n it is offline   Reply With Quote
Old 10-15-2012, 10:27 PM   #7
what kind of floor do you plan to install in the bathroom? if you plan on tiling you will have to cover the whole floor with plywood before putting down cement board or membrane and wouldn't really have to do anything to the subfloor other then the reinforcment underneath like you planned.
Old 10-16-2012, 12:09 AM   #8
Rewards Points: 115
It'll be tile. Plan on Plywood -> Ditra -> Tile. The beams have nearly a 4' span, so I'll be reinforcing in addition to just the toilet area.
how do i tell what size "rough in" my current toilet is? liverlipsyyz Plumbing 12 07-20-2012 01:39 PM
Please advise on slow flushing toilet? WillK Plumbing 5 03-12-2012 09:58 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
