Reinforcing Former Stair Opening - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-06-2008, 08:20 AM   #1
Rewards Points: 1,062
Question
I removed the stairs between the first floor and the basement. Does the reinforcement proposed in the illustration make sense ? These are 2x10s.
Thanks,
- a -
Old 06-06-2008, 09:39 AM   #2
Registered User
Termite's Avatar
That looks like it will work just fine.
Is there a wood ledger on the brick wall? If there isn't, I see why you're installing the header and hanging the tail joist off of it. Be sure to use joist hangers. I'd also make an effort to keep the header as close as reasonably possible to the brick wall since the plywood floor sheathing will be overspanned the way it is currently drawn. 24" is the maximum span for 23/32" rated floor sheathing.
Old 06-06-2008, 09:56 AM   #3
no wooden ledger. thanks for reminding about joist hangers - i was just gonna shoot some 3-inch framing nails from my makita but i guess doing both will be better.
- a -
rough opening for glass block oxicottin Remodeling 5 05-04-2008 08:01 PM
Opening for attic stairs sk8z Remodeling 16 03-17-2008 12:52 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
Recessed pull-down attic stair BlueTheCow Carpentry 4 10-31-2007 05:54 AM
Framing Opening Length captainron19 Carpentry 3 04-01-2006 10:50 AM
