Old 11-28-2007, 09:10 AM   #1
Reinforcing cabin
We built a cabin 9 1/2 feet off the ground, It has an open loft, but we are noticing that that when you walk up the porch or in the center of the cabin it shakes. How do we reinforce?
Gami is offline   Reply With Quote
Old 11-28-2007, 03:30 PM   #2
Woodworker and Contractor
Kingfisher's Avatar
Reinforcing cabin
First you need to post more info or you will just get asnwer like this
Bracing
What is the cabin sitting on walls, posts, brick, stone, concrete, jello
How wide and long is it did you use wind bracing for the open ceiling or beams. Is it a kit, plan or just winged it.
Post these and I'll try to help
Kingfisher is offline   Reply With Quote
Old 11-29-2007, 10:25 PM   #3
Reinforcing cabin
It is on post that are cemented in concrete. The cabin is 24 wide by 38 long with porch, but roof extends over porch. Porch is open concept. I'm sending picture of inside and outside hope this works.
Old 11-29-2007, 10:28 PM   #4
Reinforcing cabin
oh and it was just winged. We found some plans online and used them, just from print outs.
Old 11-30-2007, 08:22 AM   #5
Kingfisher's Avatar
Reinforcing cabin
Did you set the post in concrete holes or did you pour then in a continuos footing connecting one post to the other? Did you place any x bracing on any of the post? What size are to post and how are they placed? what size are the floor joist and what is their span? Plywood siding, sheating, or siding?
Reinforcing dirt walls in crawlspace Fix-It Chick Building & Construction 8 01-13-2008 12:57 PM
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 12:41 PM
Building Cabin.. Can I use cedar deck 5/4 radiusx6 on floors? Going Nuts Flooring 1 07-19-2006 07:37 PM
Hybrid log/pole barn cabin kybldr Building & Construction 2 01-01-2006 11:49 PM
