#16 |
Reinforcing Beam with Steel Plates
Adding 2x10s to the sides of the steel plates would make this a very wide beam, and yes, the extra weight would go on to the columns.
If you definitely, positively, desperately want to go down the route of fixing steel to the outside (not really recommended), then it would be better to use steel angle, say something like 6x3, where the outstand 3" leg serves to stiffen the steel to prevent it buckling. But you still need input on where and what type of fixings you need. The labour is a DIY proposition, but the design isn't. This is what people are trying to tell you. Last edited by tony.g; 07-31-2012 at 03:36 PM. |
#17 |
Albertom,
you have gotten excellent advise from multiple posts ..... however none of these replies are providing you with what you WANT, but they provide you with what you NEED. If someone you do not know (or their level of knowledge or experience) says its OK to do what you want, WOULD YOU?????
Gary "You get what you pay for, and sometimes free costs more!" |
| The Following User Says Thank You to GBrackins For This Useful Post: | tony.g (07-31-2012) |
#18 | |
Framing Contractor
Reinforcing Beam with Steel PlatesQuote:
If you can afford to finish your basement....you can afford to pay an engineer. Bottom line here is that you will never get an answer on this forum...its impossible. Use your head and do the right thing.
Joe Carola |
#19 |
I understand. I'll either forget about taking the lolly column out or call an engineer. Contractors that have done some of this work in the past have told me to put up 2 plates on each side but I know how that goes. You have a car noise and everybody has an answer to what it is, without asking the qualifying questions. Again, I appreciate and welcome all input. Thank you.
#20 | |
Framing Contractor
Joe Carola |
#21 | |
Good luck!
#22 |
Residential Designer
Engineers, Architects and designers take a on a lot of liability for the money they charge.
Especially engineers and they are worth the money. They will mathematically justify the design they come up with. Andy.
Residential Drafter/Designer To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#23 |
Civil Engineer
When you discuss this project with your engineer, you should allow them the flexibility to examine a variety of alternatives besides the external flitch plate concept you proposed. There are several other potential ways to strengthen the beam, and you should certainly consider replacing the beam with a properly sized one to carry the entire load. Your engineer should be afforded the flexibility to look at every reasonable alternative, and select the most cost effective one for your circumstance.
If you plan to do the work yourself, that would figure into the decision about which option to select. Since cost appears to be a major factor in your approach, you should definitely make a point of informing any potential engineer you may want to hire what your expectations are (you want a written design, you want stamped plans, you want the engineer to meet with the building inspector to obtain a permit etc.), and the maximum you are willing to spend. No point wasting the engineer's time making a site visit to your place if their typical fee exceeds your allowable budget. |
#24 |
You can contact this company, http://www.betterheader.com/ They make flitch plates and may give you the info you need without spending $$$.
David www.DeanColumn.com |
| The Following User Says Thank You to DeanColumn1 For This Useful Post: | tony.g (08-01-2012) |
#25 |
Ok. Well I hired an engineer who charged me $700 but what he came up with is. (2) steel plates 3/8"x9"x 13' bolted to the outside of my current beam which currently consists of (3) 2x10's. I have attached some pictures of the print provided to me. Maybe it can help someone else in the same type of situation.
The only thing in question is that I spoke to a couple other engineers who have suggested staggering the top bolt holes from the bottom bolt holes. I know there are some engineers here and contractors that have done this. any suggestions? |
| The Following User Says Thank You to Albertom For This Useful Post: | AndyGump (08-30-2012) |
#26 |
Framing Contractor
Keep the bolts just like he shows. That bolt layout is part of the engineering. We have seen it called out both ways. That is money well spent. Glad to see that someone took good advice here, spent some money, and will sleep very very well.
#27 |
Reinforcing Beam with Steel Platesthank you for posting back, keep us updated after its completed. Install the bolts as shown, if you change anything on the drawing then any issues are on you and not your engineer! Good luck!
| Tags |
load bearing beam ![]() |
| Display Modes | |
| Residential Steel I beam pockets must be secured? | stevatchis | Building & Construction | 1 | 07-15-2011 10:26 AM |
| deflection in 8" Steel I Beam? | BlueBSH | Building & Construction | 22 | 07-08-2011 04:14 PM |
| Pole barn vs steel I beam building. Do they compare structurally? | viper | Building & Construction | 0 | 05-23-2011 07:17 PM |
| Steel Beam in Basement | Heinz | Building & Construction | 2 | 11-10-2007 01:11 PM |
| Steel Beam or Wood Reinforcement for 2nd floor addition? | coralhead1 | Building & Construction | 2 | 06-06-2006 02:22 PM |
