Reinforcing 6x6 Pressure Treated Deck Posts - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-31-2010, 07:18 PM   #16
the Musigician
DangerMouse's Avatar
ummmmmm....
wow.......
DM
Old 01-31-2010, 07:22 PM   #17
Civil Engineer
Rewards Points: 4,856
As noted by others, the splits in the posts are the least of your problems. This is at best a strangely designed and constructed deck. The framing design is poor at best, there are numerous inadequate connection details, nails are missing from connectors etc. You really need to bring in someone who knows proper deck construction procedure to fix the problems before your deck falls over.
Old 01-31-2010, 07:28 PM   #18
Originally Posted by jweiner View Post
The posts are buried four feet into the ground with concrete. The post holes are 18" diameter (4 feet deep) - so there is a lot of concrete in each post hole.
Typically the posts should be connected with a metal bracket on top of the footing so the post is not inside the footing. See the attached photo link.
http://www.nachi.org/images09/post-base-connection.jpg
wnabcptrNH is offline   Reply With Quote
Old 01-31-2010, 07:37 PM   #19
Do you have any pics of how the deck is secured to the house ?
Ledger board thru bolted ?
Danger is if not secure to the house, & given the lack of metal brackets from beams to joists the whole thing could pull away from the house & collapse
Old 01-31-2010, 07:46 PM   #20
Also, why do none of the trim boards meet? the guy who built this deck did a weird job doing all the trim.
IMHO I think you should have another contractor look at this deck because it needs to be fixed. If you paid a lot of money to have this built you dont want anything to happen to it.
Old 02-01-2010, 07:51 PM   #21
Joel
The ledger board is 2x10 and is attached to the house with carriage bolts in each box sill. The ledger board was installed by the builder when the house was built and I know this was done properly. What can be done to help strengthen the deck at this point?
jweiner is offline   Reply With Quote
Old 02-01-2010, 08:10 PM   #22
Support the deck pull out the posts, attach the proper brackets, notch the posts like shown above, and carriage bolt the posts through the beam into post.
Old 02-01-2010, 08:13 PM   #23
Posts are buried...so I doubt that is going to happen
You need metal brackets attaching the beams to the posts, & joists to the beams
In some cases the support may need to be replaced/resupported
You really need someone one-site to look at this IMO
Too much going on to see it all
Old 02-01-2010, 08:20 PM   #24
Problem with the brackets is that the post is not sitting directly under the support beam so its offset so that wont work. If the guy who built you house built that deck I would call him back in to look at it. If he refuses find out what the code is in your area and if it doesnt meet code he has to fix it unless its beyond the statue of limitations in your state. Looks like a newer house so you should be within your rights to have him back to fix it.
The law at least in NH and MA is that if the contractor builds something that doesnt meet code or standard construction methods you have 7 years to make a claim to them (ie statue of limitation is 7 years)
Old 02-01-2010, 08:20 PM   #25
Joel
All the joists are in joist hangers at the ledger board, but the joist are not in hangers at the perimeter of the deck (where the rail is). Should there be joist hangers there too? I will get some heavy duty L-brackets to take care of some of the problems and will have an expert take a look at it in the spring.
Double Level Deck 6x6 posts Skytree Building & Construction 3 09-07-2009 10:47 AM
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 07:03 PM
Deck Posts replacement with load bearing columns from Pacific Columns, Inc Bruce Wilson Building & Construction 7 05-24-2009 02:55 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 04:24 PM
