Reinforcing 6x6 Pressure Treated Deck Posts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-29-2010, 01:48 PM   #1
Joel
Question
My deck is supported with 6x6 pressure treated posts which are about 4-5 feet tall. I noticed some vertical splitting of the posts which makes me a little nervous. I am wondering what would be the best way to reinforce these posts. Thanks in advance for any help.
jweiner is offline   Reply With Quote
Old 01-29-2010, 03:51 PM   #2
the Musigician
DangerMouse's Avatar
some vertical splitting is normal and nothing to worry about. do you have pictures?
DM
Old 01-29-2010, 03:54 PM   #3
unless they are like half the width of the column dont worry about it at all. People used to frame houses with 2x4's 24" on center and those houses are still standing and I am sure they are all cracked pretty good. A 6x6 has a vertical compression limit much higher than anything you could ever put on it
wnabcptrNH is offline   Reply With Quote
Old 01-29-2010, 03:56 PM   #4
the Musigician
*Bingo*
DM
Old 01-29-2010, 04:27 PM   #5
Joel
Here are some pics
Here are the best pictures I could get of the splitting.
Reinforcing 6x6 Pressure Treated Deck Posts-dsc04735.jpg   Reinforcing 6x6 Pressure Treated Deck Posts-dsc04734.jpg   Reinforcing 6x6 Pressure Treated Deck Posts-dsc04732.jpg
Old 01-29-2010, 04:31 PM   #6
thos 6x6's are fine but what the attachment detail to the deck beams? One of those pictures doesnt look right.
Old 01-29-2010, 06:25 PM   #7
Yeah, what is attaching the 6x6 posts to the deck ?
Best method is cutting them, so that the joist are sitting on the post (not my deck)
Old 01-29-2010, 10:03 PM   #8
Registered User
Rewards Points: 526
So many questions....... Extend the downspout roof water away from the buried posts so you don't get frost heave, posts shouldn't be buried, the doubler has a one foot piece on the end for strength? Did someone else build this? If you give more pictures from 6' away, we can help make your deck safer. Does the deck have the solid blocking required between joists over all bearing points that is missing in Dave's picture? Did you use surface pier blocks as seen under the shims in the picture? The splitting is normal, though the post bottoms may be in water.
Be safe, Gary
Old 01-31-2010, 09:00 AM   #9
Joel
Here are some additional pictures of my deck's substructure. It is a two level deck as you can see, so some of the understructure appears a bit odd.
Reinforcing 6x6 Pressure Treated Deck Posts-dsc04747.jpg   Reinforcing 6x6 Pressure Treated Deck Posts-dsc04746.jpg   Reinforcing 6x6 Pressure Treated Deck Posts-dsc04745.jpg   Reinforcing 6x6 Pressure Treated Deck Posts-dsc04744.jpg   Reinforcing 6x6 Pressure Treated Deck Posts-dsc04743.jpg
Old 01-31-2010, 09:01 AM   #10
Joel
A few more pictures . . .
Reinforcing 6x6 Pressure Treated Deck Posts-dsc04741.jpg   Reinforcing 6x6 Pressure Treated Deck Posts-dsc04740.jpg   Reinforcing 6x6 Pressure Treated Deck Posts-dsc04739.jpg   Reinforcing 6x6 Pressure Treated Deck Posts-dsc04738.jpg   Reinforcing 6x6 Pressure Treated Deck Posts-dsc04737.jpg
Old 01-31-2010, 09:12 AM   #11
Usually metal brackets are used to attach joist to the beams
Are the posts on cement piers for support, not just sitting on the ground ?
Old 01-31-2010, 09:49 AM   #12
Joel
The posts are buried four feet into the ground with concrete. The post holes are 18" diameter (4 feet deep) - so there is a lot of concrete in each post hole.
Old 01-31-2010, 11:19 AM   #13
jlhaslip's Avatar
Rewards Points: 2,884
this doesn't look right to me.
Isn't there a building inspection done in your area?
those things are just hanging in mid air?
Reinforcing 6x6 Pressure Treated Deck Posts-dsc04740.jpg   Reinforcing 6x6 Pressure Treated Deck Posts-dsc04742.jpg
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 01-31-2010, 06:55 PM   #14
holy crap did that pass an inspection? if so that inspector should be fired. Those support posts are toe nailed into the 2x support beams when they should be notched and lab bolted. Those supports are done completely wrong
Old 01-31-2010, 06:57 PM   #15
Yeah, I would not trust the way that is supported
Especially that "corner" joist hanging from a 1x
Double Level Deck 6x6 posts Skytree Building & Construction 3 09-07-2009 10:47 AM
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 07:03 PM
Deck Posts replacement with load bearing columns from Pacific Columns, Inc Bruce Wilson Building & Construction 7 05-24-2009 02:55 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 04:24 PM
