-   -   Reinforcing 6x6 Pressure Treated Deck Posts (http://www.diychatroom.com/f19/reinforcing-6x6-pressure-treated-deck-posts-63123/)
jweiner 01-29-2010 01:48 PM
My deck is supported with 6x6 pressure treated posts which are about 4-5 feet tall. I noticed some vertical splitting of the posts which makes me a little nervous. I am wondering what would be the best way to reinforce these posts. Thanks in advance for any help.
DangerMouse 01-29-2010 03:51 PM
some vertical splitting is normal and nothing to worry about. do you have pictures?
DM
wnabcptrNH 01-29-2010 03:54 PM
unless they are like half the width of the column dont worry about it at all. People used to frame houses with 2x4's 24" on center and those houses are still standing and I am sure they are all cracked pretty good. A 6x6 has a vertical compression limit much higher than anything you could ever put on it
DangerMouse 01-29-2010 03:56 PM
*Bingo*
DM
jweiner 01-29-2010 04:27 PM
Here are some pics
3 Attachment(s)
Here are the best pictures I could get of the splitting.
wnabcptrNH 01-29-2010 04:31 PM
thos 6x6's are fine but what the attachment detail to the deck beams? One of those pictures doesnt look right.
Scuba_Dave 01-29-2010 06:25 PM
Yeah, what is attaching the 6x6 posts to the deck ?
Best method is cutting them, so that the joist are sitting on the post (not my deck)
http://www.nachi.org/forum/attachmen...43-medium-.jpg
Gary in WA 01-29-2010 10:03 PM
So many questions....... Extend the downspout roof water away from the buried posts so you don't get frost heave, posts shouldn't be buried, the doubler has a one foot piece on the end for strength? Did someone else build this? If you give more pictures from 6' away, we can help make your deck safer. Does the deck have the solid blocking required between joists over all bearing points that is missing in Dave's picture? Did you use surface pier blocks as seen under the shims in the picture? The splitting is normal, though the post bottoms may be in water.
Be safe, Gary
jweiner 01-31-2010 09:00 AM
6 Attachment(s)
Here are some additional pictures of my deck's substructure. It is a two level deck as you can see, so some of the understructure appears a bit odd.
jweiner 01-31-2010 09:01 AM
6 Attachment(s)
A few more pictures . . .
Scuba_Dave 01-31-2010 09:12 AM
Usually metal brackets are used to attach joist to the beams
Are the posts on cement piers for support, not just sitting on the ground ?
http://public.blu.livefilestore.com/...Q/IMG_2594.jpg
jweiner 01-31-2010 09:49 AM
The posts are buried four feet into the ground with concrete. The post holes are 18" diameter (4 feet deep) - so there is a lot of concrete in each post hole.
jlhaslip 01-31-2010 11:19 AM
2 Attachment(s)
this doesn't look right to me.
Isn't there a building inspection done in your area?
those things are just hanging in mid air?
wnabcptrNH 01-31-2010 06:55 PM
holy crap did that pass an inspection? if so that inspector should be fired. Those support posts are toe nailed into the 2x support beams when they should be notched and lab bolted. Those supports are done completely wrong
Scuba_Dave 01-31-2010 06:57 PM
Yeah, I would not trust the way that is supported
Especially that "corner" joist hanging from a 1x
