Old 03-31-2009, 05:50 PM   #1
Question
reinforcement in a shed foundation footer - yay or nay ?
i am planning to set a 3.5' deep foundation footer for a small 10 x 12 ft storage shed. do you all think i should reinforce it with a simple rebar coral-like structure (vertical posts in corners connected by two levels of horizontal beams, one near the bottom, one near the top) or would that be an overkill ?
thanks.
Old 03-31-2009, 06:21 PM   #2
Xtreme DIY'r
Why 3.5' deep?
Is it attached to the house?
I put in a 12" cement "foundation" all the way around - no rebar
Then I added on to my shed, 10 x 22 now
The only reason I did 12" is to keep mice out
I'm filling with gravel/rocl/sand & putting pavers in
Its a pool cabana & I may need to get to the pipes
Old 03-31-2009, 06:58 PM   #3
Master General ReEngineer
Bondo's Avatar
Ayuh,... A 3, 1/2' foundation sounds alittle Overkill for a 10 x 12 ain't it,..??
I'm doing an 8, 1/2' x 11, 1/2'er pinned thru p/t 2x4s, on compacted limestone....
A floating slab would provide Alot of support,+ stability...
Old 03-31-2009, 08:26 PM   #4
Concrete & Masonry
I take it your going this deep due to grade issues. Either way, 1/2" rebar grid on 2 foot centers each way (imagine 2' squares between rods) is well worth the money.
jomama45 is offline   Reply With Quote
Old 04-01-2009, 07:32 AM   #5
gravity always wins
You didn't say where you are, so I assume you're going deep to get below frost line. No matter, re-bar is overkill in a small shed footer as long as it's on undisturbed earth. It's not like you're going to have any great point loads on the foundation. A lot of houses don't even have re-bar in the footers.
Old 04-01-2009, 10:48 AM   #6
washington DC, i am doing 3.5 ft because the frost line is like 3 ft although there is the global warming effect too. i do not want a floating slab because there will be water and power coming into it.
Old 04-01-2009, 01:07 PM   #7
Xtreme DIY'r
You don't really need 3.5' footer on a detached shed of that size
I have pool pipes going in & out of my pool cabana as well as a solar heating setup. I've never had a problem
Old 04-01-2009, 01:10 PM   #8
how deep do you recommend ? i don't want any ground swelling/floating to cause pipe breakage etc.
Old 04-01-2009, 01:16 PM   #9
Xtreme DIY'r
Mines only 12" deep - and that was simply to prevent mice from getting in. Also to prevent rot & match the existing 10x12 shed
My pipes are buried maybe 24" deep
They do come up inside the shed
Install a drain valve so you can drain the water in the winter
Some people blow out the water in the lines
Mine stay full of water about level with the ground
Foundation for 8x10 Vinyl Shed fireberd350 Building & Construction 17 03-04-2012 05:49 PM
garage floor, foundation, footer questions? wengr General Discussion 1 03-24-2009 09:01 AM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
Shed Wiring bcdal Electrical 12 03-26-2008 05:51 PM
Foundation for a 12X14 Shed emaizar Building & Construction 1 04-01-2007 05:04 AM
