Refactory Clay - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-16-2007, 12:41 PM   #1
Refactory clay
How do you use refactory clay on firebrick? Do you mix with sand only or do you use cement too.
Thanks.
rehirsch is offline   Reply With Quote
Old 12-16-2007, 03:28 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,638
You might try this Question in the HVAC forum,........
It's not really a general Building & Construction question......
Old 12-16-2007, 04:14 PM   #3
Rewards Points: 1,232
If you mean fireclay, as in a dry powder that is very inexpensive, you do it like this:
Empty the fireclay nto a 5 gallon bucket. Gently cover with water. Do not stir! Keep covered with water for 24 hours, then pour off the excess water and mix throughly.
To use the fireclay, do not lay joints as in normal brickwork. All you want to do is butter the firebrick to chink the gaps between them. Joints should be less than 1/4" maximum.
If you are doing anything outside, you should buy a premixed refactory cement, and still lay the firebrick with 1/4" or less joints.
Tscarborough is offline   Reply With Quote
Old 12-16-2007, 06:51 PM   #4
Refactory clay
Tscarborough,
Thank you that is the information I need. I am building an outdoor BBQ and needed this information to continue. Once I get it done, I will post a picture.
Thanks.
REH
Andalusa Clay tile from Honduras Tom Roofing/Siding 3 06-29-2013 08:39 AM
clay cap around foundation? patrickosu Building & Construction 5 08-21-2010 04:55 AM
Improving Drainage in Clay Soil BigJimmy Landscaping & Lawn Care 1 03-23-2007 12:03 PM
Clay Problem twaters12 Landscaping & Lawn Care 4 01-31-2007 08:09 PM
Painting a terra cotta clay tile roof? xoroniox Painting 2 12-13-2006 12:30 PM
