Refacing Rubble Concrete Foundation Footings - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-24-2006, 03:30 PM   #1
refacing rubble concrete foundation footings
My new house has a very rough 'rubble concrete' perimeter footing as a foundation and has lots of pits and grooves (it's an old, old house). I would like to improve its appearance and reduce the amount of moisture that seeps into the pits and grooves by covering it with another material - either smooth concrete or stone.
Ideally I'd like to face it with natural stone and am wondering how I go about ensuring that the stone becomes bonded with the foundation wall permanently - I've seen this type of thing where the stones pull away from the foundation over time (that would be bad).
Any help or referals to other sites much appreciated.
Buck
Buck is offline   Reply With Quote
Old 10-24-2006, 05:33 PM   #2
Rewards Points: 1,230
You can't bond dimensional stone to a wall; it must sit on a foundation. You could use synthetic stone, or you could simply apply a layer of stucco to the foundation, using a good bonding agent.
Tscarborough is offline   Reply With Quote
Old 10-25-2006, 01:36 PM   #3
Thanks! Do you think it would be feasable to skim coat the surface with cement or something other than stucco? Otherwise, do you have a recommendation as to a high quality bonding agent?
Buck
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
Repair Opening in concrete foundation jr66 Building & Construction 2 05-14-2007 12:32 AM
Math check on amount of concrete for poured foundation? Badfish740 Building & Construction 10 05-05-2007 07:49 AM
Concrete shed footings in a marsh/wetland? tigerbalm2424 Building & Construction 11 03-27-2007 07:37 PM
footings and foundation walls surfsupinhawaii Building & Construction 4 09-04-2006 12:35 AM
