Redwood 2x4's - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-18-2009, 11:07 AM   #1
Redwood 2x4's
Are redwood 2x4's acceptable to use as a floorplate when framing a concrete basement?
lsuchor is offline   Reply With Quote
Old 02-18-2009, 11:14 AM   #2
the Musigician
DangerMouse's Avatar
i think so.
DM
Old 02-18-2009, 11:33 AM   #3
Remodeling Contractor
yes you can. It is naturally resistant to rot and is what a pressure treated lumber is trying to imitate. Just not as commonly used today because of the high cost compared to yellow pine.
Old 02-18-2009, 03:04 PM   #4
knewbie
curapa's Avatar
How bout I trade you some pressure treated 2x4's for your redwwod 2x's.
ParkerFenceandDeck.com
curapa is offline   Reply With Quote
Old 02-18-2009, 03:31 PM   #5
Registered User
Termite's Avatar
Agreed, you can use redwood for mudsills and bottom plates, as it is decay resistant and insect resistant (source: IRC section 319). You're likely going to get some strange looks from most people for "wasting" good redwood that way.
Old 02-18-2009, 03:44 PM   #6
I am using redwood because that is what I saw my dad using 10 years ago to finish his basement other than that there is no reason. For studs I am using some 2x4's that I get when I recieve a shipment of goods at work. The shipper nails the 8' boards to the floor of the trailer. I just pull the nails and put them in my truck to use on my basement. Most are straiter than you can get at HD. I figure I have saved the money on them to spend the money on the RW. The boards on the floor of the trailer are to hold the pallets steady. I am not stealing anything from my employer
Old 02-18-2009, 04:15 PM   #7
Registered User
Termite's Avatar
There's absolutely no advantage or disadvantage to using redwood besides the excessive cost. If it makes you feel better then go right ahead!
Old 02-18-2009, 04:40 PM   #8
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,732
Ayuh,... The Ultimate in "Green Technology",.....
Recycling Dunage,...
I design most of My projects around what's currently showing up in jobsite Dumpsters.....
I agree with the sentiments noted above,...
Seems like a Waste of Redwood,..
'course being a Northeaster,... I don't see much of it,...
If you're Buying it,... I'd go for the P/T stuff instead myself...
Bondo is online now   Reply With Quote
Penofin TRANSPARENT REDWOOD RED LABEL good for Redwood fence? tomas21 Painting 5 08-18-2008 12:22 AM
Which Caulk to use with Redwood? 1655graff Painting 2 06-17-2008 11:56 AM
Decking - Redwood vs. Cedar davidr Building & Construction 3 08-26-2007 10:31 PM
