Reducing Door Frame Size - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-22-2010, 04:02 AM   #1
reducing door frame size
I have an interior passageway that was originally framed (with header and king and jack studs) to fit 5 foot wide french doors that were never installed. Now I want to reduce the framing to fit a 4 foot wide pair of doors instead. Is it enough support to put only one stud on each side of the new pre-hung doors? (This is what I have already done) I just read that to properly support the doors I need two studs nailed together on each side. Will one stud on each side support the door frame?
lisaallison is offline   Reply With Quote
Old 10-22-2010, 05:43 AM   #2
Adding another 2x4 to each side would at most cost you an additional $8 at Home Depot. It will make the support of the door a lot more solid.
duckdown is offline   Reply With Quote
The Following User Says Thank You to duckdown For This Useful Post:
oh'mike (10-22-2010)
Old 10-22-2010, 06:01 AM   #3
DIY staff
Rewards Points: 7,174
A single stud may twist or sag---My guess is you already drywalled that?
Fix it or take a chance--Your call----Mike---
Old 10-22-2010, 03:11 PM   #4
Thank you both so much for your quick answers. No, I didn't drywall yet, just being lazy, I guess I better do it. Ugh!
Another question.....do I shim behind hinges or under? What size screws to attach jamb to studs? (I'm terrible at nailing).
Old 10-23-2010, 06:05 AM   #5
DIY staff
I usually place the shims just above or below the hinges so that the shim can be nailed through the jamb.
I've never screwed a jamb--always nailed---If you pre drill a hole for the nail you will find the nailing job easier---
You can use old Jims trick of using a nail as a drill bit--Just nip off the head with a pair of cutters.
---Mike---
lisaallison (10-24-2010)
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-25-2011 11:29 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 12:08 AM
Reducing ductwork size - implications? wdbdesign HVAC 2 03-24-2009 07:17 PM
reducing pipe size for sink drain bluebee1314 Plumbing 5 12-02-2007 12:53 PM
Reducing size of very large air-vent returns in floor? AllGoNoShow HVAC 3 09-19-2006 09:36 PM
