Old 01-22-2011, 08:23 PM   #1
DIYer
Reducing the amount of concrete used by increasing aggregate?
For environmental and cost reasons, I'd like to minimize the amount of concrete poured for a small 12x10 footer/stem wall foundation I'm doing
I have lots of pieces of broken up old concrete available ranging in size (1/2 gravel all the way up to large chunks)
I have read that adding more aggregate would not affect the strength of the resulting concrete so long as the fines and cement could fully cover all pieces. True?
dwoloz is offline   Reply With Quote
Old 01-23-2011, 12:38 AM   #2
Not true.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 01-23-2011, 07:53 AM   #3
Buying the first round
LIHR's Avatar
There is science behind the formula for concrete, and size and type of aggregate is a very important element of that formula. Do a quick search on proper aggregate for concrete.
If this was a non-critical mix such as a pad to place your garbage cans on I'd say go ahead and throw it all in, but being that it's not, I wouldn't reinvent the mix.
LIHR is offline   Reply With Quote
Old 01-23-2011, 11:26 AM   #4
And just how much are you going to save by mixing in chunks of busted concrete? Are you going to site mix or get the concrete delivered? You could save even more by substituting old bed frame rails for re-bar.
Tigerloose is offline   Reply With Quote
The Following User Says Thank You to Tigerloose For This Useful Post:
Willie T (01-23-2011)
Old 01-23-2011, 07:53 PM   #5
Concrete & Masonry
I take it that part was a joke???
I wouldn't add any broken up concrete to the premix or ready mix and expect desired strength of the finished product.
jomama45 is offline   Reply With Quote
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
How do you measure poured concrete PSI? head_dunce Building & Construction 18 02-25-2007 09:58 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 05:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
