Redoing Siding, To Insulate Or Not Insulate - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-15-2011, 08:49 AM   #1
Rewards Points: 29
I have been planning on re siding the house this year, its an older house that has had aluminum siding for prob 40 years. I noticed on the aluminum backer looked like it has some type of insulation on it. Should I replace with the 9'X3'X1" pad insulation? Or can I get away with not? There is siding that comes with insulation but the price of the siding with it is close to 700$more then plain vinyl insulation and pad.
Shawn
Shawnzy is offline   Reply With Quote
Old 05-15-2011, 09:40 AM   #2
Kerry-All Pouch creator
Woodsmith's Avatar
Send a message via MSN to Woodsmith
I'd go with the insulation, Shawnzy.. I see you're in Ontario and it can get cold there in most regions, or hot! Either way, the insulation should help keep your energy costs down. You'll probably recoup the extra costs in a few years.
Good luck with the project!
Woodsmith is offline   Reply With Quote
The Following User Says Thank You to Woodsmith For This Useful Post:
Tom Struble (05-15-2011)
Old 05-15-2011, 05:50 PM   #3
Rewards Points: 29
thanks woodsmith, just needed a positive answer haha how is nailing into the insulation with siding over top? anytips?
Shawn
Old 05-15-2011, 06:00 PM   #4
Woodsmith's Avatar
I had the vinyl siding replaced on my house a year and a half ago. They had some plain looking nails that went through the 1" Styrofoam insulation they used and into the old siding (cedar, perhaps).
I guess the type of nails will be determined by what you're nailing into. Just check with a vinyl installer, see what they use.
Proper way to Insulate and stucco a wood siding house?? clone477 General DIY Discussions 5 01-20-2011 09:47 AM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
