Old 02-19-2009, 10:42 AM   #1
Redoing flat ceiling to a vaulted ceiling
I have a room above a garage 28'x22' with the rafters going the long way.
Can I make this into a vaulted ceiling without tearing the roof off?
I am thinking I could tack 2x10's or 2x12's alongside the existing rafters
and then cutting off everything below on the old rafters. Is this something that can be done or am I way off base. Any other ideas?
sgtrock is offline   Reply With Quote
Old 02-19-2009, 11:05 AM   #2
SDC
SDC's Avatar
Your ceiling overlays (joists) are keeping your exterior walls from spreading.
If you remove them what will keep the walls from bowing out? To do this properly it needs to have load calculations and a load bearing ridge beam. The ridge will carry the load of the roof both ends of the beam will need to be posted through the house to the foundation.
There are of coarse other ways to do this, scissor type rafters going from the top plate to mid-span of opposing rafter and vise versa.
Now if you have trusses up there...don't even think about it
SDC is offline   Reply With Quote
Old 02-20-2009, 02:19 AM   #3
perpetualjon's Avatar
Check out this page. Towards the bottom is the "scissors truss" that could be used to replace the cross beams on your original room structure. You'll still need an engineer's help to determine the loading and required design.
perpetualjon is offline   Reply With Quote
knotty pine vaulted ceiling raghib Building & Construction 32 05-09-2012 10:25 AM
Crown moulding with a vaulted ceiling? cstrat Carpentry 34 06-17-2011 07:51 PM
HELP! lighting question for vaulted ceiling pauls General Discussion 5 07-03-2010 05:53 PM
Running wire to a Ceiling Speaker (in vaulted ceiling) rgmetro Electrical 1 01-09-2008 11:27 AM
Vaulted Ceiling, faux wood beam, ceiling fan? zel Electrical 9 07-13-2007 06:30 PM
