-   -   redesign truss (http://www.diychatroom.com/f19/redesign-truss-11687/)
locorner 09-20-2007 07:46 AM
redesign truss
I HAVE A 30x40 POLE STYLE SHOP WITH 10' WALLS.
I WANT TO OPEN THE TRUSSES THAT ARE CURRENTLY W'S. I WAS THINKING BOX OR SCISSOR TYPE, MAYBE USING METAL TO OPEN COMPLETELY.
ANYONE HAVE EXPERIENCE DOING SO?
crecore 09-20-2007 11:47 AM
I was involved with doing it once, but it wasnt that large. (Customer changed their mind). We had to draw up new plans, get them stamped for on site reconstruction. If yours isnt living space you might get away without the stamp (depending on locale) but it's a good idea either way. You may need to add a beam for one, or sister the floor joists, etc.
Hard to do much more educated guessing without a drawing, local codes, loads, pitch, etc. When the original trusses were designed and what load criteria was used would make a difference as well.
locorner 09-21-2007 10:29 AM
I can send you a drawing, their are 3 trusses to redo.
Thank you for your reply.
jiggyjack 09-21-2007 09:27 PM
ANY alteration that you make to truss has to be approved by an Engineer.
That being said, the easiest way to do this would be attach a 2 x 10 to the top chord with the appropriate birds mouth on the tails. Leave a gap in the middle so you can slip in a 2 x 12 ridge board. Each new rafter will have to be braced up before you cut the trusses. Also put the new 2 x 10 at 12" OC. That means that you will have a extra 2 x 10 in between each truss.
Hope this make sense.
joasis 09-22-2007 04:12 PM
I would advise proceeding with extreme caution before cutting up an existing truss....if you aren't sure of what you are doing, it may be worth some of your time and a few bucks to get an experienced contractor in for an opinion.
