Red LED Lighting Inside Of In-Wall Entertainment Center - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-23-2010, 10:50 AM   #1
HABSFAN2006's Avatar
Rewards Points: 150
Red LED lighting inside of In-Wall Entertainment Center
I am about to start my next project.
The fireplace is built, and the plasma is hung above it.
Off to one side, will be an in-wall entertainment center,
with PS3(DVD), Satelite receiver, and Amplfier.
I need lighting inside this unit. I've been considering puck
lights, LED lights, etc.
But I really want to make an impression, and try to learn something
new at the same time.
What I really want to do, is insert red LED light strips inside the unit,
and figure a way to have light reflect on all three shelf levels.
I think this would really show well next to the electrical fireplace that is already there.
Does anyone have any good step-by step articles regarding this type of installation. ( much confusion between 12v, 24v, 120v bulbs, and transformers / switches need )
Or better yet, any pictures or ideas to share?
Feel free to share!
thanks,
Jay
Life is an experience... Learn from it!
HABSFAN2006 is offline   Reply With Quote
Old 11-23-2010, 11:21 AM   #2
Rewards Points: 5,336
You can buy red rope lights and just plug them in.
Ron
Old 11-23-2010, 12:08 PM   #3
Rewards Points: 150
Ron
That's a good idea Ron. I will have to look into the specifics. I believe they are LED. The thing is, I'll have three compartments to light, seperated by 5/8" thick shelves, and I only have +/- 18" wide to work with, so unsure if they bend to a small radius.
Old 11-23-2010, 12:32 PM   #4
They are sold in coils at the local stores with a 6" radius.
Ron
Old 11-23-2010, 12:41 PM   #5
I have seen LED lighting strips available on "tape", probably less than 1/4" thick total. The ones I saw can be set to nearly any color or to rotate through the colors. Bend radius can be quite small.
I don't think it too hard to find this stuff online.
oberkc is offline   Reply With Quote
Old 11-23-2010, 02:38 PM   #6
Rewards Points: 1,644
I think when I was in Ikea this weekend they had them.
bob22 is offline   Reply With Quote
Basement moisture - why not seal inside wall? BRO931 Building & Construction 10 08-30-2010 01:47 PM
How to Insulate? Wall inside wall... jbatl Building & Construction 4 04-29-2010 09:20 PM
Problem putting in some wiring for entertainment center mikereno1 Electrical 3 02-20-2009 01:02 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Minimum Clearance to Vent Inside Wall? MikeinBurien Plumbing 12 12-05-2005 11:03 PM
