Recommend A Good Top Layer Material Please - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-16-2011, 10:07 PM   #1
Rewards Points: 87
recommend a good top layer material please
We have lots of effloresces in our old poured concrete basement and they are actively growing and very quick. Few weeks or few months later you will see them again after a simple clean. That means we do have serious moisture issue from the soil because of the bad poured concrete. We can see the huge differences between the original 50sí concrete wall and the 80sí or 70sí addition concrete wall. One is flat and smooth with enough cement and water when it was poured; another is uneven and shows too many gravels and sand were used when it was poured. So I plan to put a layer of fine cement to fill in those small holes to reduce the moisture passages, use something like this Quikrete 50 lb. Non-Shrinking Precision Grout. Do you have any better material to recommend?
We have done two big projects started from last summer: exterior grading and French drain (not down to the foundation) to make sure surface water will have no chance to close to our foundation; interior French drain to make sure no water will come from ground. Now it's time to reduce moisture issue.
recommend a good top layer material please-img_2833.jpg   recommend a good top layer material please-img_2834.jpg
diy001 is offline   Reply With Quote
Old 06-17-2011, 05:05 AM   #2
Too Short? Cut it Again!
You might try concrete restoration products from someplace like
www.abatron.com
I've used some of their concrete products but mostly wood restoration materials. There are no doubt other companies like them out there so use the link above as a starting point.
Old 06-17-2011, 06:37 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
I've used Xypex for the exact problem you have and it's worked successfully.
http://www.xypex.com/index.php
Old 06-17-2011, 11:55 AM   #4
Rewards Points: 87
Can you tell me the of product you used? is it called XYPEX CONCENTRATE?
Old 06-17-2011, 12:50 PM   #5
Try this link.
http://www.hi-dry.com/
Are they good Shenandoah Cabinets good quality? robertmazzo Carpentry 76 05-14-2015 09:23 PM
What is a good tear/rip proof material? VIP! thebunnyexpert General DIY Discussions 3 03-05-2010 09:20 PM
Is this a good method for repairing chimney crown/liner crack? meltdowndave Roofing/Siding 4 03-04-2010 07:56 AM
Recommend me a good Garbage Disposal BlueBSH Appliances 6 01-09-2010 09:12 PM
material prices coax Electrical 2 02-08-2005 05:23 PM
