Recoating Plaster Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-28-2010, 04:40 PM   #1
recoating plaster walls
Some areas of my plaster walls started cracking and falling apart. The painted surface AND the hard plaster "top coat" started coming off in large pieces. I believe this was due to moisture from a gutter problem that is now repaired. I have removed all of the loose paint and plaster "top coat" and now I am left with a 5'x8' area that is down to the rough sand-like layer of the plaster. I would like to skim coat or add the "top coat" back to this surface and then repaint. How do I go about accomplishing this task on my own?
Thank you,
SLR
compassslr is offline   Reply With Quote
Old 03-28-2010, 05:08 PM   #2
Rewards Points: 5,336
Thank you,
SLR
You would need to be sure the keyed rough coat was properly adhered to the substrate. If the top coat came off, was the rest of the wall compromised?
Ron
Old 03-29-2010, 08:45 AM   #3
ccarlisle's Avatar
40 sq ft?? That's a major repair job for the few remaining real plasterers left...these are the guys who used to do real plastering jobs applied by hand and with the three coats - and most are really plaster "artists".
And most would go right back to the laths...
Because gettting three layers of plaster absolutley flat is indeed an 'art'. Most plasteres nowadays would cut out the whole mess and replace it with drywall.
We had a job last month where a water leak from above put a 12 sqft hole in ceiling plaster of a 1920s house. We got estimates from real plasterers and it turned out that we replaced the whole ceiling in less time that it would have taken otherwise. That's more a DIY job than trying to get 40sqft nice and smooth and flat using real plaster.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 03-31-2010, 12:35 AM   #4
Registered User
Rewards Points: 5,204
Or, if it's job security: http://www.plaster-wall-ceiling-solu...questions.html
Be safe, Gary
Venetian Plaster FYI Plaster Ayn Painting 10 07-01-2010 12:26 AM
Basement Walls Plaster what to do? The Vintage Sou Building & Construction 5 11-19-2009 04:42 PM
Can you texture plaster walls? destes50 Painting 5 11-06-2009 10:51 AM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 01:10 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 06:27 AM
