Reclaimed Bricks (repointing) Soft? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-04-2010, 06:23 AM   #1
Reclaimed Bricks (repointing) soft?
Hi All,
My home was built in the early sixties with reclaimed bricks and the exterior brick work is in need of repointing.
My problem is that I have read that older bricks are softer and need special morter. I do not know if my bricks are the soft type. Is there a way to tell?
The morter that is there now seems to be regular portland cement type.
I have had a mason over for an estimate and I am happy for him to do the job but he says the bricks are the soft type and that all I need to use is regular morter.
Online articles I have read say that regular morter used with old soft bricks will cause fast deterioation. Currently I have many gaps in the morter, some of the bricks are cracked (like down the middle) and there is some spalding occuring where the surface of some bricks seems to be seprating off (not a lot of this though).
Can anyone please advise?
Thank you
davidwarner is offline   Reply With Quote
Old 05-04-2010, 06:46 AM   #2
Rewards Points: 4,538
all depends on how old ' reclaimed ' is, doesn't it,,, i'd suggest you find another mason who can tell the difference just to be sure,,, you're correct in your mortar decision but its extremely difficult knowing the difference to anyone who hasn't been involved in the historical restoration of brick structures.
do NOT use today's mortars on old brick,,, you need to use a slaked lime mortar ( google it ) which'll be more forgiving & flexible to the old brick.
age gaps aren't unusual in old mortars & cracked brick's not uncommon, either,,, SPALLING will usually occur if the brickwork hasn't been treated w/silicone siloxane,,, even brick needs help now & then
Old 05-04-2010, 07:35 AM   #3
Hi,
Thanks for the quick replyIs there anyway me as a layperson can test the bricks or things I could look for to help determine if my bricks are the older soft type?
Or what about the original morter? Is it possible to tell if that is the regular portland type? I figure that if it is, it should be safe (or at least no worse) to use the same for repointing.
Also my bricks seem to be a slightly differn't size (9x3.5 inches). Does this help determine their age or consitency?
Tanks again
Old 05-04-2010, 09:50 AM   #4
Rewards Points: 582
It depends on your climate to some extent. If you have a lot of wet weather followed by freezing night time temperatures, a strong cement mortar could damage the bricks.
The chances are that it was built with cement mortar in the 60's.
stuart45 is offline   Reply With Quote
Old 05-04-2010, 09:59 AM   #5
So if cement was used originaly would it be innapropriate to use something differn't to repoint?
I live in Michigan with quite a bit of wet weather and repative freezing/thaw.
What about the bricks with cracks, should I fill these in with caulk or something?
Old 05-04-2010, 10:09 AM   #6
Rewards Points: 582
If the original was cement mortar, I would probably go for a 1/1/6 lime/cement/sand mix. As stated by itsreallyconc a siloxane sealer would help the brickwork. This would allow it to breathe.
A good mason should be able to tell the type of bricks and mortar used.
Old 05-04-2010, 10:34 AM   #7
OK, thanks for all comments
Old 05-05-2010, 05:29 AM   #8
NEVER caulk brickwork,,, #1, it looks like hodge-podge & is; # 2, whoever sees it will know whoever did it was an idiot or incompetent at the least; # 3, its the wrong mtl !
that's why we have an item call'd ' re-pointing ' !
ps - IF your bricks're the soft 1's, NO diamond grinders w/tuckpoint blades, either !
Old 05-06-2010, 02:03 AM   #9
"ps - IF your bricks're the soft 1's, NO diamond grinders w/tuckpoint blades, either ! "
Why not?
Old 05-06-2010, 07:31 AM   #10
because the normal ham-fisted jabonie causes too much damage to the existing brick when you give them power tools,,, IF you're careful, ok - use it,,, it doesn't take long to develope the nec skill & it IS your house don't forget a mason's brush, water spritzer, & blower, either
Old 05-06-2010, 07:54 AM   #11
Rewards Points: 582
Use a lump hammer and a plugging chisel to be safe. If the joints are soft it should be easy.
Old 05-06-2010, 10:56 AM   #12
I don't plan on doing the work myself. I looked in the yellow pages for a mason and was planning on going with this guy except he said he would use normal mortor on my old bricks. He also said he would be useing a grinder on the old morter.
Repointing 90 year old chimney in western Wa Windows Building & Construction 17 02-26-2010 11:14 AM
Silver solder on previous soft solder joints GPS10 Plumbing 2 01-27-2010 05:34 PM
Use stone dust under bricks to form a border around flower bed Curious123 General DIY Discussions 4 08-23-2009 04:41 PM
Paver Sand and Blue/Grey Colored Bricks Curious123 General DIY Discussions 4 08-13-2009 09:22 PM
Problem with bricks in fireplace box pulling away from interior wall proofer Building & Construction 1 06-15-2008 08:54 AM
