-   -   Recessed Cans fall right in the middle of my drywall seam... What do i do?? (http://www.diychatroom.com/f19/recessed-cans-fall-right-middle-my-drywall-seam-what-do-i-do-18450/)
AndyH 03-13-2008 01:09 PM
Basically if i start my 4x8 foot sheet in the corner, the recessed can will fall directly on the seam that i will have to finish. I'm assuming i cannot mud and tape a seam with a recessed can in the middle of it. The only other option i believe i have is to start my sheet 2 feet out from the wall, so that the cans fall in the middle of the sheet. This sucks because i will have much more taping to do,obviously because I will have to start the drywall out about 2 feet on each side of the wall
the ceiling dimensions are 148X216 inches.
I realize that i can hang the drywall parallel to the studs, however i really do not want to do that, I want to do it the correct way, 90 degrees to the studs.
any ideas on how i should lay out my drywall
p.s. im using 5/8 on the ceiling and 1/2 on the walls
perpetual98 03-13-2008 01:36 PM
Can't you use 10' or 12' sheets?
AndyH 03-13-2008 01:42 PM
1 Attachment(s)
I already purchased the dryall. The length of the sheets doesnt matter, its the width.
AndyH 03-13-2008 01:44 PM
Wanted to put up a couple of pics so you get the idea of what im talking about. No matter what wall i start hanging from, the cans fall right on the middle of a 48 " seam.
AndyH 03-13-2008 01:45 PM
1 Attachment(s)
another pic
AndyH 03-13-2008 01:53 PM
I guess i could hang the sheets parallel along the studs, however i want to avoid as many "waves" as i can.
I have already shimmed some of the low studs. Any ideas??
AtlanticWBConst. 03-13-2008 02:20 PM
You CAN ABSOLUTELY have a seam at a recessed light opening. That happens all the time. Same concept as electrical light switches. They always fall in the middle of 4' sheets, placed on the horizontal.
perpetual98 03-13-2008 02:21 PM
If you cut the first sheet in half, you'd only end up with 1 extra seam to tape, right?
AndyH 03-13-2008 02:23 PM
Really???? I figured someone would tell me that it would make that area much more susceptable to cracking or something like that.
Are there any special instructions i need to know when i get ready to tape and mud that area???
AndyH 03-13-2008 02:24 PM
One side already has to be cut in half because the ceiling width is 148". Im trying to avoid having to cut another sheet
AtlanticWBConst. 03-13-2008 02:28 PM
Normally, we install strapping 16" OC, over the underside of the joists. That allows the placement of the additonal strapping lengths (which serve as a screwing surface), closer to the recessed can's lip.
AndyH 03-13-2008 02:32 PM
Well... Do u think ill be okay if my recessed light cut out have to be made in the middle of my tapered edges??
AtlanticWBConst. 03-13-2008 02:35 PM
When you attach your sheet. Router, or cut out the light opening. Then place a 12" length of strapping near the light. Hold it, so that it is 1/2 on the attached sheet, and 1/2, protruding out. It will be perpendicular to the attached sheet, and right next to the light's lip. Hold it tightly, and install about 3 to 4 dryall screws into the sheet (and thru the strapping behind it) to attach them solidly together.
Do this on one side of the light. Then attach another 12" length on the other side of the light. The strapping should be firmly attached.
When you install the next sheet, you will cut out the light openings, and install screws thru the edge of the next sheet and into the strapping that is attached to the other sheet. That will lock the floating edge seam together.
AndyH 03-13-2008 02:38 PM
Originally Posted by AtlanticWBConst. (Post 107340)
When you attach your sheet. Router, or cut out the light opening. Then place a 12" length of strapping near the light. Hold it, so that it is 1/2 on the attached sheet, and 1/2, protruding out. It will be perpendicular to the attached sheet, and right next the the light's lip. Hold it tightly, and install about 3 dryall screws into the sheet to attach it solidly to the it.
Gotcha, thanks !!!!
AndyH 03-13-2008 02:54 PM
Now that i imagine it. The way i have position the lights to make it even, i will only be able to put one peice of strapping. Not all the lights are perfectly center in the studs. I had to adjust a few of them. The seam is going to go DIRECTLY through the middle of the light opening.
