Recessed Bath Tub Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-03-2008, 08:46 AM   #1
Rewards Points: 1,062
Question
recessed bath tub framing
hello,
hope everyone is doing well.
i am finally ready to install my recessed bath tub, one of those that come with an integrated wall on the exposed side so you do not have to put your own cover (tiles etc.).
one short side of the tub will be leaning against a wall and there i can frame it tightly but i want the other short side to be against a stylish wall of glass bricks, which will be separating it from the toilet. the concern comes to whether framing that does not rely on the wall on that side (but those on the other short side and the back long side) will be sturdy enough ? i do plan to have framing on that side as well but it will only be a rectangle matching the side of the tub fastened to the floor and the frame on the tub's long side, NOT the wall that corresponds to it because it is glass bricks.
Q1: will this compromise for style be sturdy enough or should i scratch the glass brick idea ?
Q2: is there any way to fasten that portion of the frame to the glass brick wall (seriously doubt that) ?
thanks,
- a -
Old 06-03-2008, 10:11 AM   #2
Registered User
Termite's Avatar
Why not build a "structural" kneewall to support the shower walls, and stack the glass blocks above it for good looks?
Bath Box drainage all gone bad. HELP shwingirl Plumbing 14 01-03-2008 04:25 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 02:52 PM
Recessed light plan foiled? kcrossley2 Electrical 8 03-14-2007 11:08 PM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 09:27 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
