Rebuilding A Patio Cover - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-15-2012, 12:40 AM   #1
rebuilding a patio cover
I'm thinking about rebuilding a patio cover on a house I just bought. The patio cover that is up is really built poorly. The problem that I'm having is can I mount new posts on not level concrete slab.
ONEMORETIME is offline   Reply With Quote
Old 04-15-2012, 12:43 AM   #2
Rewards Points: 13,752
Post some pictures.
Think about it, just cut the post differant lengths.
Old 04-15-2012, 01:52 AM   #3
Rewards Points: 79
Search these forums, there are a few threads on folks who have done this. Some have fastened to the slab, others have cut the slab out and poured a deeper footing. Your local code matters here. My local code for example says the slab must be at least 3.5" thick in order to attach anything to it.
juryduty is offline   Reply With Quote
Old 04-15-2012, 04:47 PM   #4
rebuild porch ideas
hear is some photos on the current patio cover.
Old 04-15-2012, 08:29 PM   #5
cortell's Avatar
Rewards Points: 504
You can if you want it to look bad and be structurally unsound.
I suggest you break the slab at the footings and pour new ones that are level.
cortell is offline   Reply With Quote
Patio Cover Design Question? Rclancyc Building & Construction 3 10-04-2011 01:07 PM
leaning patio cover... kemerick Building & Construction 2 07-14-2009 04:37 PM
Wood Patio Cover Post Grounding Madracki Electrical 10 07-04-2009 02:49 PM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 02:53 AM
Patio Cover - Need help/suggestions DIYer Building & Construction 7 02-19-2006 09:00 PM
