Old 07-08-2012, 09:01 PM   #1
Rebuilding of the house and regrading the backyard
Neighbor that adjacent to me in the back of my backyard is planning to rebuilt his house and raise rear yard grade by 5 feet.
His construction will create drainage hazard to me and neighbors on the both side of subjected property. As I understand, future raised backyard supposed to have retaining wall on the perimeter of the property. So, water is going to drain thru weep holes toward me? Please let me know how to handle this issue and is such kind of construction allowed in NJ?
Thanks a million
sundres01 is offline   Reply With Quote
Old 07-08-2012, 09:46 PM   #2
GBrackins's Avatar
I would recommend the following:
1. talk with you neighbor and raise your concerns. ask if they plan on weeps holes and will the top of the retaining wall actually be higher than the finish grade on their side of the wall. you may have to remind them their post-construction run-off cannot exceed the pre-construction conditions. typically a retaining wall that high (depends of your building code) requires it be designed by a professional engineer. their engineer should be aware to address the run-off issue.
2. inquire with the local building department about your concerns. if they say there is nothing they can do or regulate about it ....
3. find a local civil engineer and discuss the issues with them. they would know what your local regulations are in regards to storm water run-off. you may have to spend money hiring them, but the flood you prevent may be more than worth the cost ....
4. check and see if there is a local board of appeals where you can appeal the proposed construction. I can only speak about board of appeals in my area, but they are normally established locally to address such concerns. Again it would depend on your location and the authority of the board.
I have typically found that #1 usually will take care of issues, unless you don't get along with your neighbor. there is when the other items must come into play.
Not sure if this well help you, but at least it should help to point you in the right direction. Again items such as them tend to have a very local flavor, so the suggestions I have given you may or may not apply to your local jurisdiction.
Good luck and post back with the outcome please.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following 2 Users Say Thank You to GBrackins For This Useful Post:
mae-ling (07-26-2012), sundres01 (07-08-2012)
Old 07-08-2012, 10:08 PM   #3
Thanks a lot, i will let you know the development of that issue
Old 07-26-2012, 02:58 PM   #4
GBrackins's Avatar
sundres, any update on your situation?
Gary
The Following User Says Thank You to GBrackins For This Useful Post:
Looking To Buy A 100 Year Old House...Some Problems Medic-5150 Building & Construction 3 09-24-2011 10:57 PM
regrading around house eddytheflow Landscaping & Lawn Care 4 06-21-2011 09:56 AM
Considering buying a house that needs regrading HELP Dr.JUSC Landscaping & Lawn Care 9 06-16-2011 11:58 AM
regrading away from the house... jarheadoo7 Landscaping & Lawn Care 1 06-10-2011 10:46 AM
Will gravel around house help drainage? evolve Landscaping & Lawn Care 9 05-30-2011 03:23 PM
