Rebuilding A Garage Roof - Rafter Vs Truss - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-29-2012, 06:51 PM   #31
Rewards Points: 26
A month later here is my follow up with pictures.
Using sash cord I hoisted a 12 foot beam, made of two 2x6's screwed together, up to the ridge board
I started with a single jacking point on top of the mid wall.
I soon realized the the beam would twist under load so added some plywood stays screwed to the rafters to hold the beam steady.
One jacking point eventually became six. Three points to jack and three points to bolster the beam.
I jacked the roof up to the point I was comfortable with.
I fastened 14 collar ties each 2x6x16'.
I removed the posts allowing the roof to settle.
The end result is the roof still has a bit of a sag but much less dramatic then it was. I would like to have gotten it perfectly straight but I am happy with the results considering. Total material cost was about $250.
Rebuilding a garage roof - rafter vs truss-img_5979.jpg   Rebuilding a garage roof - rafter vs truss-img_5981.jpg   Rebuilding a garage roof - rafter vs truss-img_6176.jpg   Rebuilding a garage roof - rafter vs truss-img_6177.jpg   Rebuilding a garage roof - rafter vs truss-img_6178.jpg
ksm1000 is offline   Reply With Quote
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
How to support garage roof -- cutting header for new addition amy6152 Building & Construction 11 03-21-2012 01:36 PM
Garage Roof Rafter Question bobwoz Building & Construction 0 08-30-2011 03:31 PM
new double garage murray1426 Building & Construction 4 05-23-2009 01:11 PM
Cost of replacing a rafter in our roof??? bikerboy337 Roofing/Siding 3 04-24-2005 06:19 AM
