Rebuilding A Garage Roof - Rafter Vs Truss - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-29-2012, 08:45 PM   #16
Framing Contractor
Originally Posted by kwikfishron
So a homeowner cutting their roof is somehow less dangerous???
Did I say that?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 05-29-2012, 09:01 PM   #17
I keep reading on internet warnings about truss systems not being able to hold weight on roof or not being able to provide attic storage space. This is not necessarily true- the truss designer / engineer / builder just need to know what you want the trusses to do. They can be designed and built to perform however you need them.
pucks101 is offline   Reply With Quote
Old 05-31-2012, 09:31 PM   #18
True. And those are the trusses that I remember having to wait for, vs- buying them off the lot.
That's just my opinion. But it's free, so take it for what it's worth to you.
1910NE is offline   Reply With Quote
Old 05-31-2012, 10:32 PM   #19
AHH, SPANS!!!
Rewards Points: 1,166
Originally Posted by KyleInBrooklyn View Post
We are in the process of buying a weekend home in the country. I've completed an inspection of the house with all systems in pretty good shape. The roof of the detached garage (approx 20 x 20) however needs to be rebuilt. It sags and there is visible rotten wood. The rest of the structure appears sound. I suggested to my home inspector that I would rebuild the roof to the existing dimension and specs. I'm assuming it is a rafter structure - there is drop ceiling and a bunch of tarps up there currently so I couldn't see up in the existing structure.
As mentioned the garage is approx 20 x 20
It's a simple gable roof.
I intend to do do the work myself with a couple of friends.
Does it make sense to go rafters or would I be better off buying trusses?
Thanks for any suggestions.
K
it might be better to rafter frame that one. tear old roof off, re frame new roof... since you have not looked up into the space yet maybe there is usable lumber in the roof system and may not require full roof frame demo. you already have ceiling joists ( most likely?) so adding trusses will complicate/clutter the ceiling area, unless you plan on taking out the ceiling joists, why?
hand drive is offline   Reply With Quote
Old 05-31-2012, 10:59 PM   #20
Good point - I think the replies kind of got side-tracked as to which is better, rafter vs. truss. If OP is simply doing a repair, probably better to just replace exactly what's bad. Also, the permit issue may be simpler if only repairing existing rafters and replacing existing roofing/shingles.
Old 06-01-2012, 09:16 AM   #21
If you have two guys standing on the walls each with a rope and a piece of wood tied to the end and a third guy on the ground hooking the rope with the wood on it into the truss then it's very easy to pull them up. I've done it many times on wider spans on a two story house. Also doesn't take that long. But like what's been said above, you lose storage space.
angusW is offline   Reply With Quote
Old 06-11-2012, 11:26 AM   #22
Just a DIY guy
plenty of places make storage trusses. If I were doing trusses, this would be the way to go.
http://www.apmbuildings.com/attic-storage-truss.shtml
http://www.truswood.com/types%20of%20roof%20trusses.htm
http://www.midwestmanufacturing.com/...&productId=346
M3 Pete is offline   Reply With Quote
Old 06-11-2012, 11:12 PM   #23
Missouri Bound's Avatar
I have to agree with Joe....trusses are the only way to go. Setting the first truss is the lesson for the rest....and it's both a time saver and money saver,. I've built my own on small projects...not recommending that for a first timer but it is something that can be done.
Do you want it your way or the right way?
Old 06-12-2012, 08:40 PM   #24
Have to agree that it's much easier to have a crane put the trusses up on top of the walls but you still have to spread them out. For a one story building like a garage it will save a bit of time but three people can haul them up in no time. It's been a long time since I've had to get a crane, but around here they charge a minimum of 3hrs at $150/hr. That was quite a few years ago and a different part of the continent so I'm sure prices are a lot different where the OP is located at.
As far as trusses vs. a cut roof, go with trusses. With cutting rafters on a 20 X 20 garage that's approx. 130 cuts as apposed to 16 or so cuts for the ridge on a truss system. You can also figure a little over double the nails for rafters compared to trusses. Plus the time to figure out the proper rafter cut.
Old 07-26-2012, 09:09 PM   #25
Rewards Points: 26
Hi there,
Following up from this thread, I finally took possession of our summer house with aforementioned garage. There was black plastic stapled up inside the garage which blocked the view of the roof system from the inside (and presumably caught water dripping in).
I have attached some photos that reveal the situation. The roof is sagging but the rafters look surprisingly good. Rather than rebuilding the entire roof I would like to jack the ridge board back up to its original position. I'm looking for guidance on how to do this.
The width of the garage is approx 24 feet. There is a wall that divides the garage roughly in half although it's only about 8 feet high so not the full height of the garage. My idea would be to build 2 beams about 12 feet long which together would span the roof just under the ridge board supporting the roof in it's original position.
The beams would each be supported by a post at one end and the common wall in the middle built up to appropriate height and strength. Follow me so far?
My concern is that in putting pressure upward on the ridge board that the rafters will want to pull away from it. My idea is to add a collar tie to every rafter as close to the ridge board as possible. This would hopefully hold the rafters to the ridge board but also create a flat surface for the new beams to support the roof.
The rotten fascia had me thinking the whole roof need to be replaced. Seeing it now I think I can jack it up and straighten it out.
Does any of this make sense?
Rebuilding a garage roof - rafter vs truss-img_5661.jpg   Rebuilding a garage roof - rafter vs truss-img_5663.jpg   Rebuilding a garage roof - rafter vs truss-img_5664.jpg
ksm1000 is offline   Reply With Quote
Old 07-26-2012, 09:20 PM   #26
My neighbor had a sagging roof on his garage so he decided to jack it up. He braced it and used a beam to lift it...he lifted it right off the walls and it came apart with no support around the perimeter. Then he called a contractor to do it properly.
Old 07-26-2012, 09:23 PM   #27
Rewards Points: 26
Awesome!
Old 07-26-2012, 09:45 PM   #28
Originally Posted by joecaption View Post
The trusses get set inside the building upside down, one person on each side of the building and one inside with a pole made up to push on the middle of the truss to flip them over.
Yep! Done it several times...seen it done dozens of times. A 20' truss is not too heavy for 3 guys to install. The important thing is bracing as you go..and I don't mean JUST nailing to the plates.
Old 07-27-2012, 07:23 AM   #29
AHH, SPANS!!!
As you jack the ridge up keep an eye on the walls where the rafters sit on it. The walls should come/pull in at the top as the ridge goes back up. The reason the ridge dropped is because there are not enough collar ties or ceiling joists to keep the walls from spreading. Place an identifying mark where the rafter sits on the wall and watch that mark as you jack the ridge up, the rafters might pull free off the wall plate nail connection and pull up themselves without bringing the walls in with them. The best way is to use a come along in the center of the rooms' span that goes from outer wall top plate to outer wall top plate and tighten the come along as you jack up the ridge. You do not want to add any type of collar ties until you have the ridge jacked up and straight, any type of jacking support should be temporary and not impede the lifting of the ridge.
A 1/2 piece of osb ripped 1 1/2" and nailed to the underside of the ridge along with a 2x4 nailed flat to the osb will give you a base to put some type of temp ridge (4x6) that spans outward from center of the ridge in either direction, say, 10' or 12' total. This will help spread the lifting capacity while jacking up the ridge. if you can use the center wall that is there to set your jack on that would be ideal otherwise a floor to ridge 4x4 or 4x6 as the jack post. Examine where the center wall ends along the outer walls and consider how the outer walls will pull in some when the ridge is lifted. You might have to modify the edges of the center wall to accommodate the outer walls pulling inward, do you understand?
When the ridge is lifted and in place how to hold it all together? I would nail 16' 2x6 collar ties to every rafter and add hurricane ties to the rafter wall plate connection.
Old 07-27-2012, 08:05 AM   #30
Rewards Points: 26
Thanks Hand Drive, excellent advice and completely understood. I had thought about the come along idea and wondered about adding hurricane ties as well. I hope to post updated photos before too long. Thanks.
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
How to support garage roof -- cutting header for new addition amy6152 Building & Construction 11 03-21-2012 01:36 PM
Garage Roof Rafter Question bobwoz Building & Construction 0 08-30-2011 03:31 PM
new double garage murray1426 Building & Construction 4 05-23-2009 01:11 PM
Cost of replacing a rafter in our roof??? bikerboy337 Roofing/Siding 3 04-24-2005 06:19 AM
