Rebuilding A Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-24-2007, 02:13 PM   #1
Post
rebuilding a deck
I want replace my pressure treated decking with new maintance free decking. Is there any reason I can't just overlay the older (8yrs) but still in good shape pt deck?
gpouliot is offline   Reply With Quote
Old 05-24-2007, 02:44 PM   #2
Rewards Points: 1,088
Unnecessary extra weight. You'll realize that the composite boards are very heavy.
handy man88 is offline   Reply With Quote
Old 05-26-2007, 10:22 AM   #3
Darylh's Avatar
I would be worried about water getting trapped between the two.
Darylh is offline   Reply With Quote
Old 05-26-2007, 11:31 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
That would be my primary concern too. Even pressure treated lumber will breakdown and lose it's resistant properties, over time in areas of standing water.....
- Build Well -
Old 05-26-2007, 09:15 PM   #5
robertcdf's Avatar
You will want to remove your decking... You may find your frame is not in as good a shape as you think. Any issues with the frame should be fixed prior to putting down composite decking.
robertcdf is offline   Reply With Quote
Old 05-28-2007, 09:20 AM   #6
Rewards Points: 528
Do it right and remove the old ptw decking. When you remove it, you may find a lot of cracks in the top edge of the joist's where the screws or nails went in. If thats the case, you will need to attach ptw 2 X 4's to the joist's to use as a new surface for attaching the deck boards. If you install the new boards as is, then over time, theres a very good chance that the boards will move, leaving larger spacing between boards in some areas and smaller spacing in others. Don't use nails on the 2 x4's and use enough screws so it don't move.
When you select the ptw 2 X 4's, lay them on edge on the floor and pick out the straightest one's. This will help in saving some labor time when you run them parallel and level with the joists. You should also ask around from some professionals about which composits are best and why. Good Luck.
rjordan392 is offline   Reply With Quote
Old 05-28-2007, 12:08 PM   #7
robertcdf's Avatar
Well since someone else mentioned about asking pros about what brand composites to use... I will put in my 2 cents. I love Correct Deck brand composite materials. The new CX line is very nice.
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
deck questions robphelan Carpentry 6 06-25-2006 07:42 PM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 10:50 PM
deck walls maintenance Building & Construction 6 04-03-2005 11:37 PM
