Rebuilding Chimney Cap - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-01-2011, 12:39 PM   #16
mem
Rewards Points: 156
In your case I would first get rid of all that loose and cracked mortar. Then reapply a new layer nice and flat and use this layer as base for the new crown. When doing the new crown you will absolutely need some kind of bond break for the new cement, be it sheet metal or tar paper, or the expansion and contraction differential will tear your brick work apart! If you use jomama's design be sure to add a half inch half round down the middle of the two by four to get a good drip ledge.
When I was looking for the new length of flue on my project I found nearly a dozen different corner radii. I laid a piece of cardboard on my existing flue and traced the outline. I cut this out and then had a 'gauge' to carry around to find the correct profile, finally at Hamilton Parker.
Here's a drawing of my project if it may shed any additional light:
ChimneyCapPlans.pdf
I also have a nice article I ran across doing my research about the subject but it's too large, at 476k, to post. I'll be happy to send it to you if you would like. The chimney actually looks very similar to yours.
Or, you could take the easy route:
CT_CHASECOVER.pdf
They're custom so I imagine they're a bit pricey.
When it's all done, be sure to invest in a good cap for the flue. Cold rainwater striking the hot inside surface of the flue can cause it to crack and spall causing even more problems. Good luck!
mem is offline   Reply With Quote
Old 02-01-2011, 02:09 PM   #17
Rewards Points: 91
sure if you don't mind emailing me the article coltoncyoung@gmail.com
no_Wedge is offline   Reply With Quote
Chimney Confusion (Long) wehcyar Building & Construction 10 02-12-2017 06:16 AM
Chimney repair advice needed cbrc5eric Building & Construction 2 04-04-2010 06:32 AM
Concrete block Chimney problems scoggy Building & Construction 0 03-09-2010 07:00 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 11:23 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
