Rebuild Concrete Steps Leading To Basement - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-27-2009, 06:38 AM   #31
Rewards Points: 4,744
you did make certain the drain worked 1st, right ? ? ?
now to finish the job, excavate the exterior wall sides & coat them w/thoroseal ( or similar product ),,, better yet, use an asphaltic-based roofing cement & cover the trowel'd on coating w/miradrai,,, that will prevent moisture/water/soil acids from infiltrating the wall or attacking the cement's lime &, eventually, rotting the block.
NEVER sign your work so you can always blame someone else
Old 09-27-2009, 10:16 PM   #32
Rewards Points: 1,088
Originally Posted by gruntman View Post
Thanks, wow that took me a year you are right! Yes, signed and dated it on the bottom step.
How does the water drain again? Is it piped out?
If not, what do you do when it rains and the bottom fills up with water?
handy man88 is offline   Reply With Quote
Old 09-30-2009, 11:55 AM   #33
gruntman's Avatar
Rewards Points: 79
I dug a hole about 3 feet deep and filled it with crushed stone. It never floods in the stairwell - just rainwater which the drain seems to handle well. The old one wasnt built correctly - the water just drained into a hole with about 2 inches of rock and then dirt (it was all for show). Installling a pipe to bring the water away from the house might have been a good idea but I think given the amount of water I get I dont think I needed it for this job.
gruntman is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Concrete steps Shadowchase Building & Construction 5 07-04-2008 06:01 PM
Need help replacing some concrete in my basement. zmurphy Building & Construction 8 01-17-2008 08:10 AM
Leaking Basement - Concrete jeepwillies Building & Construction 2 03-06-2007 07:42 AM
Framing 2 concrete posts in middle of basement yummy mummy Building & Construction 20 01-16-2007 02:14 PM
