Rebar Requirements For Concrete Footings - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-16-2008, 05:06 PM   #1
rebar requirements for concrete footings
I'm building a 2 story deck and need to pour new footings. These are to be 26"x26"x24" min. w/2 rebar "mats" in #5 rebar. I'm not sure of the proper method of constructing these mats. Do I use 4 pieces and make a square, or do I need more pieces. The building inspector didn't specify and its not on my detail sheets.
palmspringsguy is offline   Reply With Quote
Old 06-17-2008, 05:06 AM   #2
space 4 20" pcs of #5 in a tic-tac-toe layout - btm mat 8" high & 2nd 8" above that,,, could tie-wire the intersections but that only helps during placement so the bar doesn't move.
yesitsconcrete is offline   Reply With Quote
Rebar Placement in a 3x3 concrete pad. Top, bottom or middle? Deck Building & Construction 32 05-11-2008 08:44 AM
footings vs pylons smarbaga Building & Construction 1 03-26-2008 09:53 PM
Vertical rebar support. jrepp Building & Construction 6 11-22-2007 05:28 AM
Rebar Trees trout_baller Landscaping & Lawn Care 5 06-20-2007 05:39 PM
Concrete shed footings in a marsh/wetland? tigerbalm2424 Building & Construction 11 03-27-2007 06:37 PM
