# Of Rebar In Cinder Block Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-07-2010, 08:57 PM   #1
retaining wall project
johnlvs2run's Avatar
# of rebar in cinder block wall
I'm checking for info and would like to know the standard for a 6x64' cinder block wall on clay flat ground, as an open space divider between properties. This would be in Cali, not in an earthquake zone. I've seen three different standards, and would like to know which would be best for the wall.
1a) One 8'x5/8" rebar for every 4 feet (3rd block), i.e. 22 rebar, filling only the blocks with the rebar. This has been the most common response;
b) One rebar for each cinder block on foundation, i.e. 48 rebar, filling only the holes with the rebar;
c) One rebar every 4 feet, plus horizontal rebar on every 2nd row. This also comes out to 48 rebar.
2) Would additional rebar be used in the foundation and how much.
3) I've seen suggestions to either leave the non concrete holes open, or to fill them with concrete or dirt. My preference would be for compacted dirt, rounding the top with concrete, and sealing the wall with surface bonding cement.
johnlvs2run is offline   Reply With Quote
Old 08-07-2010, 10:03 PM   #2
Rewards Points: 1,092
Sounds like an engineer should be consulted. Good luck. j
Old 08-07-2010, 11:15 PM   #3
concretemasonry's Avatar
Rewards Points: 2,640
Check with the local code office.
Because masonry privacy walls are so common in CA, they may have some standard plans for the area (based on local wind and seismic conditions). These are usually free and they will always help with permits if an inspection is required, since inspections are usually a money loser for the county/city.
Dick
concretemasonry is online now   Reply With Quote
Old 08-08-2010, 10:48 AM   #4
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 826
There's a California company called RCP Block, and they post standard engineered construction details for CMU wall fences for low and high seismic zones (with a list of zip codes as to which area is which) on their website, all good for 2007 California Building Code.
Aggie67 is offline   Reply With Quote
The Following User Says Thank You to Aggie67 For This Useful Post:
jomama45 (08-08-2010)
How to Repair Cinder Block Foundation Cracks Germwise Building & Construction 4 07-01-2010 11:14 AM
Creating passageway through cinder block wall ...? mark_p Building & Construction 7 09-14-2009 08:22 AM
Installaton of Exterior French Door in 8" Block Wall kgt55 Building & Construction 6 06-20-2009 09:59 AM
Cracks In Block Wall Foundation vf100 Building & Construction 7 08-20-2008 09:48 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
